ORACLElights
Peak Sponsor (Level 2)
- Dec 29, 2019
- 246
- 1,336
- 2,035
- Metairie, LA
- Website
- www.oraclelights.com
- Jeep Gladiator
- Occupation
- Automotive LED Manufacturer
Light up the darkest area of your Gladiator with ORACLE truck bed lights! Featuring dual IP67 waterproof strips, this new kit matches function and design by illuminating your entire truck bed with a pair of 60-inch LED strips. Add extra light to your vehicle to see in all the dark corners or to give extra visibility at nighttime.
Working with tools late at night? Offroading in the country? Getting ready for tailgating season? Whether you use your truck for business, pleasure, or a little bit of both, ORACLE’s LED truck bed lights are the perfect addition to your Gladiator.
photo by Jim Smith
Installation is a simple process and can be completed in under 15 minutes with our plug-and-play connector that can go directly into your wiring harness. Just remove the 3M adhesive backing, and set your kit firmly in place underneath the rim of your truck bed. Then, wire the LED bed lights to a 12V source like your car battery or exterior light. Because every vehicle is different, our kit comes with zip ties and other fasteners to help you install your LED truck bed lights.
Because your Jeep was made to go off-road too, you won’t have to worry about these LED bed lights getting damaged by the elements. With an IP67 IEC rating, our LED truck bed lights are protected from any contact with harmful dust and full immersion in up to a meter of water.
Package Includes:
- (2) 60” Truck Bed Light Strips
- (1) Plug & Play Wiring Harness
- (1) On-Off Switch
- (2) Set Zip Ties
Product Specifications:
- LED Type: 5050 SMD
- Input Voltage: 12V
- Lighting Color: White
- Net Weight: 420g/14.82oz
- LED Strip Length: 60"
- Housing: IP67 Waterproof
- Running Life: 30,000 hrs
- Materials: LED Chip+Silicone
- Warranty: 1 Year
Install Video:
photo by Jim Smith
Package Includes:
- (1) On-Off Switch
- (2) Set Zip Ties
- Warranty: 1 Year
Install Video:
