Lunentucker
2021 Jeep Gladiator Mojave
People Work?
One thing that has bugged me, and is one of the primary reasons for my spending an hour's pay on the USB manual, is the lack of a collective source for torque specs.
I've been through the manual, section by section, and captured every torque spec table I saw, and they have been labeled and arranged by categories. In a couple of cases, I have added updated specs and they are clearly noted in red.
Most of the specs are good for 2020-2023 model years, but if you every have any questions or doubts, feel free to toss another "What's the torque?" post out there and see what you get.
All specs are factory components. If you have installed any aftermarket components then you should be following those manufacturers' guidance, NOT the factory specs.
There are folders and there's also a zip file that contains all of the tables.
Main Folder
Download the Zip File (Also Attached to This Post)
If you notice something's missing, let me know and I'll try to add it, but I think I have most, if not all, that the average and the advanced owner/mechanic might need.
Revised 3/15/23 - Added socket sizes to Pitman arm nut. 42mm can be tricky to find, but 1-11/16" works great and may be easier to come by.
Revised 3/21/23 - Noted Hard Top to body bolts are 13 ft lbs in 21 and 22 Owner's Manuals. Service Manual lists 9 ft lbs, which seems really light.
Revised 3/24/23 - FRONT SUSPENSION - Revised lower ball joint torques to differentiate between aluminum knuckles and cast iron knuckles (Mojave)
Commodus
Buck
San Diego, Ca.
Hydro Blue Gladiator, BMW X3
Main Folder
Thanks for the info. just what I needed
JETNC
NC
2021 Gladiator
Customer Support Coordinator
Nice job! Thanks!!
Dougstdig
Doug
FL
Main Folder
Retired CRO
You get an "Atta boy". 👍 If you get 1,000 of them. That makes you a man among boys.
Just remember that one "oh shit" wipes the slate clean.
Dougstdig
Doug
FL
No idea what you're saying here. 🤷🏻‍♂️
had an issue with the link... too much time on the computer this week for work and my patients were ----- long. no big deal.
Lunentucker
Lunentucker
People Work?
Did you get in? Maybe a work firewall had you jammed up.
Dougstdig
Doug
FL
Free2roam
Robert
Does the drivetrain one include the 442 foot pounds of torque for the diesel?
