bod925
Hey all - looking to order my first Gladiator! Trying to determine which powertrain to get. I will be upfront and say cost is not a factor in the decision, just want the best performance for my application.
I will be ordering the Rubicon trim. Test drove with the 3.6 and it just seemed a little bit lacking on get-up and go power (merging on ramp, passing on interstate, going up mountain roads). Unfortunately there are not any Rubicon trims with the 3.0 ecodiesel that I can test drive to compare.
So I asked a guy at the dealership and he told me (based on his personal Gladiator Rubicon with 37's) he thinks the 3.6 would be better for what I described above IF an air intake is added to it. He says with the turbo lag on the ecodiesel, the 3.6 would be just as good with an aftermarket air intake due to the Rubicon having 4.10 gearing standard with the 3.6 pentastar. He said the 4.10 gearing is more important than the extra torque provided by the ecodiesel using 3.73 gears for going up the hills, passing acceleration, and such.
Just wanted to get others thoughts. The ecodiesel is more maintenance and finicky with the emissions, so if all other things are equal and there is not much of a difference after adding an air intake to the 3.6L then I guess the gasser route I would go.
Has anyone driven both setups (3.6L w/4.10+intake VS. 3.0L w/3.73) and could comment if they notice a difference between the two powertrains?
Will not be doing any towing.
