37’s and .410 gears
monkeyman
Arizona
2020 Gladiator Rubicon---2004 Wrangler TJ
Anybody running 37” tires on your stock rubicon with .410 diffs and seeing 8 th gear much?
hjdca
Southern California Mountains
You won't... The RPMs are too low at hwy speeds and the resistance too much to allow the tranny to up shift.... and with the boxy shape of the Gladiator when you hit higher rpm "speeding ticket" speeds, the air resistance is too much to allow the tranny to up shift.
Minty JL
Jeremy
Ft Meade, MD - AOR
23 XC90 - 23 JTM - 19 JLUR - 04 355 ZQ8
USA(R), DoD - MD TM lead - Field Operations
I have my JTM on 37x13.5 and OEM 4.10s.......yeah not much 8th gear action.
Doing 4.88s like my buddy soon to get it back.
SuperBeast
Pittsburgh
‘21 JTR
I have 37” Mickey Thompson Baja Boss MT on stock Rubicon 4.10s with a 4.5” lift. I see 8th gear regularly but I’m usually at 60-65mph on the interstate. It’s a daily driver in the hills of Pittsburgh and I’m getting 17.5mpg with a spare 37 under the bed but otherwise empty bed. So yes, it’s possible but much over 65mph and that experience changes quick.
Panthers65
Brent
Atlanta, GA
NA
Account Manager
It's do-able, but you won't win any races. running 37" BFG MTs with the 4.10s, but have 5.13's sitting waiting to be installed. MPGs really aren't that bad, with the Jeep it's more about aerodynamics than anything else, if you run 80 it won't matter what gears you have your mileage will suck.
I pulled my boat over the weekend, probably 4K total. You definitely know it's back there and it struggles on the uphills, but it's about as fast as I'd want to go while towing anyways.
personally I'd go with the 37's, but budget money in the near future to regear.
JarHeadLV
Gerard
Las Vegas
2023 Jeep Gladiator Mohave, 2020 Porsche 911 Turbo
Financial Retirement Planner
I have a 2023 Mojave with stock 4.10 gears and x comp 37x13.5r17. I rarely do drive on freeway but it does't get into 8th gear. I have tried a few times manually to put into 8th gear on perfectly flat ground, but it's practically useless powerwise.
I'm going to have to re gear soon
JarHeadLV
Gerard
Las Vegas
Absolutely NOT calling your "bluff" here but I wonder how your getting into 8th gear? Does the different x fer case have anything to do with it? (vs a Mojave x fer case) I wonder if it's because the MT tires are very light??? My Mojave doesn't get into 8th unless I do it myself.
dans1911
Daniel
Deltona, FL
2023 JT, 2001 WJ, 1999 WJ, 1999 TJ
Assistant Store Manager, for an auto parts store
2023 Sport with 4.10s and 37x13.5 X Comp MTs. Central FL, I see 8th gear frequently on highway and city if I'm easy on the gas pedal.
SuperBeast
Pittsburgh
‘21 JTR
The short answer I think is that I generally drive slow. 55-60mph is the sweet spot, unless there’s a headwind then it’s more like 50 but I and drivers around me rarely have the patience for that!
JarHeadLV
Gerard
Las Vegas
I drive slow also, but a little faster than you ! I typically drive 65-70 on freeway
RealMcCoy
Fayetteville
2020 Jeep Gladiator JT
Lol..you got that right..
Jeep Gladiator 37’s and .410 gears 69827455679__2FE19E8B-C0DA-44AA-99FA-F6B56C458E9B
HooliganActual
Robert
10 miles from the Sun
I'm running 37" Toyo R/T's with the stock 4.10's and scaled it about 2 weeks ago at 600# over GVWR. I get 14mpg around town and mid 15's on the highway. I will see 8th gear on long flats, downhill or with a tail wind but not many other times.
It's livable...certainly 4.88's would be the way to go.
Jeep Gladiator 37’s and .410 gears 71_JeepPos
Jeep Gladiator 37’s and .410 gears 72_JeepPos
I wouldn't. But then that's almost at minimum highway speed around here.
