38 vs 37 inch tires
blackjack
Cincinnati
Gladiator Rubicon
I have seen a bunch of threads on 35 versus 37 but haven't seen much on the 38" use. I don't quite yet have my truck (hopefully any day now) but already have a set of 38x13.5" Toyo's ready on 18" rims. I am putting the 2" mopar lift on the truck. Has anyone else used these tires with this lift? Thanks.
Carlton
Chicagoland
2019 JLUR
Those are some super heavy tires at 92 pounds a piece. They also measure nearly 14.5 wide. Which wheel did you select?
JD101
Jon
Mi
2021 Gladiator Rubicon , 2021 JLU
Old thread here being revived. I ran 33s then 37s (stt pro) and now 38x13.50r17 trail graps . Yes they are heavy and my choice tire would be 39x13.50 KM3 . But the 38s are pretty much in line with the 37s. No real negative take aways . Fuel mileage is down a bit , and the tires have there own unique "character" due to tread/construction. I would reconsider 18" wheels . There are now a couple 38s that are in the 17" variety . I will also add, how you accomplish clearing the taller rubber could effect the vehicle more than the tire it's self . I wouldn't even consider running on less than 5.13s maybe 4.88 ( but that's iffy) .
