I ordered this for the oil pan. https://smile.amazon.com/dp/B00PM87W3I/ref=cm_sw_r_cp_apa_i_zB2MFbE0BEY1X?_encoding=UTF8&psc=1As topic states. Want to add an engine block and oil pan heater.
what are folks using on these
ummm, yeah I was just referring to the installation of the factory heater in the factory location. It works well in the -35°C stuff we get in Saskatchewan.@bailer Read your other thread. What do you think of it? I have never seen a dry block heater.
Something to think about, put your heater on a timer. We use heavy duty timers and turn them on about an hour before vehicle start up. Not only does it save on electricity, it saves the heating element. However, if you are up in the Artic like Paul then you might need it on as soon as you shut the vehicle off to try and maintain engine heat instead of heating a cold block.
I have used silicone pads like this for a long time. Be aware that despite similar sizes these units can have WILDLY varying power outputs.I ordered this for the oil pan. https://smile.amazon.com/dp/B00PM87W3I/ref=cm_sw_r_cp_apa_i_zB2MFbE0BEY1X?_encoding=UTF8&psc=1
Installing the Jeep block heater requires removing the alternator. Unless you're in a very cold climate, I'm not sure I would do it.
