Adjusting front and rear track bar
Geekjeep
Gladiator sport s
I’m sure a few of you have seen my last thread helping a buddy with his jeep. I just spent a ton of time under it and drawing plum lines etc. Front axle is shifted to the driver side half an inch. Rear axle is shifted to the driver side a little more than an inch. As a favor I’m going to help him adjust. I’ve always done this on a lift in the past. Doing it on the floor, can I just lengthen the trac bars and wiggle my way in Witch the tires on the ground?
Or do I need to have the front tires in the air while I’m doing it? Do I need to loosen up anything else?
Thanks
Advertisement
Walldo
East of Albuquerque
2020 Gladiator, 2006 LJR
I have always adjusted my track bars with the Jeep on the ground. Loosen the adjuster nut/clamp, drop the axle side and adjust it. Might have to loosen the frame side bolt on the track bar..
Alabama Mud Machine
Lake Martin, Alabama
This should help...
Same principle front & rear to measure.
