Alarm sounds when using key?
skindata
Josh
Ohio
2022 Jeep Gladiator Mojave
Assembly Technician
Can somebody explain why the car alarm sounds when using the physical key to unlock the door? It usually gives you a few quieter honks as soon as you open the door and then goes into full blown panic mode. Is there something I’m suppose to do to prevent that from happening before I pull the door open? I know my Silverado has the exact same thing happen whenever you try using the actual key.
Why are you using the key? Does your FOB not have an unlock button?
skindata
skindata
Josh
Ohio
Assembly Technician
The fob works fine, I’m just asking a general question on why does the alarm go off if you use the key provided to you as a back up.
The key is a backup meant to be used in a situation where the FOB isn't working, like with a dead battery. The unlock button also turns off the alarm. There is no connection between the key cylinder and the alarm system, so using the key to open the door sets off the alarm.
skindata
skindata
Josh
Ohio
Assembly Technician
Gotchya, thank you.
