Artec
Rock Sponsor (Level 1)
- Aug 21, 2017
- 23
- 86
- 121
- North Salt Lake, Utah
- 2014 JKU
Artec Industries JT Diesel Bellypan Light Weight & Tons of Protection for Vital Components !
Artec Industries' NEW JT Gladiator Bellypan is designed to give your 2021+ Jeep Gladiator ECO DIESEL full protection underneath the vehicle. Designed using CAD files directly from the manufacturer and ultra-precise 3D scans, this belly pan skid plate ensures that you have a great fit with factory components. Made from 1/4" thick 6061 Aluminum and 3/16" zinc plated steel, and CNC cut and formed, the Artec JT Bellypan Kit offers both a strong and lightweight solution for your new Jeep JT.
NOTE: 1.5"+ LIFT REQUIRED FOR USE WITH BELLYPAN
Lightweight Aluminum adds very little weight to the vehicle yet covers far more and is heavier duty than factory skids
6061 T6 Aerospace grade Aluminum is tougher than the other 5052 aluminum options on the market...there is a difference.
6061 Aluminum has a memory so when it bends, it pops back into shape...steel skid plates just dent and stay dented.
Increases ground clearance of 3/4" from factory skids and even more compared to other aftermarket skid plates
1/4" 6061 Aluminum for skid plates, 3/16" zinc plated steel brackets
Designed from factory CAD files and ultra-precise 3D scans for great and ultra precise fit.
CNC laser cut and CNC formed using custom rolled dies for high strength, unique look, and perfect contour fitment to OEM components.
All bolts under skid plate are countersunk for absolutely smooth bottom
Factory frame bolts replaced with countersunk bolts with tapered washers for improved rock clearance and less drag
All nuts are pressed into steel brackets for easy, one tool removal
Bolts directly to OEM T-case crossmember and frame using heavy duty flat head bolts that match OEM thread
No need for an aftermarket T-case crossmember for completely flat surface
Modular design lets you take off only one section for vehicle servicing
Fuel filter moves up for extra ground clearance and includes an Access Panel for easy servicing.
Protects Oil Pan, Transmission Pan, Gas Tank, Front Exhaust, mid vehicle Exhaust and Transfer Case
OEM gas tank skid is replaced for reduced weight and 3/4" higher clearance*
