BetweenToledoAndDetroit
- First Name
- Russ
- Aug 9, 2020
- 1
- 6
- 0
- Monroe, MI
- 2020 Gladiator Sport S
- Occupation
- Nurse
I’ve been stalking this site for a handful of weeks now and couldn’t find a post related to my issue. So, I’m stepping out from behind the curtain, registering as a member and asking for a little advice or insight.
We have a larger pop-up camper and trailer brakes are a must. That said, the Gladiator-specific Tekonsha harness is best described as a mythical creature; not available locally and a few weeks out at any online retailer, basics non-existent at this point in time.
That said, I went the Tekonsha harness 3024-P route with the swapped wires. A few guys on this site have done the same with reported success. I then connected the Reese/Tekonsha POD brake controller (model 7437711), hit the slide for manual brake application and got a message on the dash that there is an issue with the Auto Park and Electronic Stability Control.
I shut down the vehicle, disconnected the harness and controller, started back up with no faults.
Shut down, reconnected, hooked up trailer. Started the Jeep again and got the same faults with depression of brake pedal.
Now, I don’t know if I should haven’t, but I took the trailer on a short 1 mile tow to see if the controller worked. I never got over about 20mph in our subdivision, but the only time I could get the trailer brakes to engage was manually with the slide switch. No trailer brakes with depression of the truck’s pedal alone.
I know there’s a lot to unpack here, but any help would be appreciated.
As a note, I picked up a replacement POD controller this morning on my way to work. I’ll try it out later as we’re planning on heading out tomorrow morning to camp.
Edit 8/11/20 @ 0052:
Connected the replacement brake controller and still have the same issues.
Ran my multimeter across the red wire coming from the Tekonsha harness with the controller disconnected and I’m getting 12v with depression of the brake pedal. So, it appears the controller should be receiving the brake signal. Could this be a wiring problem with the trailer?
