Aux light/accessory switches
Ferd
Ferd
Oceanside, CA
Finance
Other than the OEM AUX switches, looking for good alternatives that don't break the bank but still work/look good. Any examples out there? Here's an example I found on Amazon.
Jeep Gladiator Aux light/accessory switches 1734620826167-1c
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
Jeep Gladiator
Automotive LED Manufacturer
Jeep Gladiator Aux light/accessory switches ORACLE_Lighting_Trigger_6_Shooter
I would definitely check out the Trigger Controllers by ORACLE Lighting.
Ready to revolutionize how you control your vehicle’s lights and accessories? The Trigger Wireless Control Systems are here to simplify your setup and elevate your off-road experience.
Why Trigger is a Game-Changer:
🔹 Wireless Control: Manage your lights at the touch of a button—from wherever you are.
🔹 Plug-&-Play Installation: No complicated wiring; just an easy, hassle-free setup in minutes.
🔹 Adventure-Ready Durability: Designed to handle extreme weather, rough terrain, and heavy use.
🔹 Instant Response: Enjoy zero delay for precise, real-time lighting control.
🔹 Seamless Compatibility: Perfectly pairs with our LED light bars, spotlights, and more.
🔹 Tailored for Performance: Tested in the toughest conditions to ensure maximum reliability.
🔗 Explore the lineup and take full control of your lighting setup today!
Ferd
Ferd
Ferd
Oceanside, CA
Finance
Where would you mount it on the JL/JT?
ORACLElights
Metairie, LA
Jeep Gladiator
The control box would be mounted in the interior of the engine bay. We actually make a mounting bracket for that as well. The Wireless controller can be mounted inside using a couple of techniques including visor mount clips.
There are vehicle specific mounting... https://www.oraclelights.com/collections/trigger-systems
Canada
2005 TJ, 2010 JKU, 2023 JTR & 2011 Ram 3500 Dually
I have the JL400 and I quite like it. Easy to install and out of the way. Looks as if it were a OEM installed option. Only down fall is the controller mounts over the battery so you have to make sure there is slack in the wiring to get it out of the way for a battery change.
Jeep Gladiator Aux light/accessory switches 20241219_084720
Jeep Gladiator Aux light/accessory switches 20241219_084701
Jeep Gladiator Aux light/accessory switches 20241219_084815
Jeep Gladiator Aux light/accessory switches 20241219_084835
Ferd
Ferd
Ferd
Oceanside, CA
Finance
Ferd
Ferd
Ferd
Oceanside, CA
Finance
I like the handle switches. Can you change the colors? What it run you$$?
Canada
You can change the colors between red, blue, green & white. I came from Amazon or you can order from Vos. It is about $200USD delivered.
unsocbl
James
Charlotte TN
2021 Gladiator Willys Eco-diesel
Another vote for the JL4000. I had it on my 21 Ecodiesel for almost 2 years. The location is perfect to quickly reach and 4 switches was plenty for me! Already ordered for the '23 overland as I plan to use the same light setup (2 bumper/2 cowl and 2 lights in the bed)
