Best paint for touching up metal body panels?
oscarach
Paul
Houston, TX
2021 Jeep Gladiator Rubicon
What Paint is the best for touching up the metal to stop rust after drilling holes for nutserts in body panels? Also for holes drilled in the chassis can you just spray them with chassis black or do you need to do primer first?
j.o.y.ride
Foster City
20 Gladiator Overland
First, most if not all the body is aluminum, so you don't need to worry about rust. Secondly, use some RTV on the nutsert before installation and no paint needed, it will seal up.
Aside from leveling, the other role of primer is to aid adhesion. When you have a huge swath of bare metal it's necessary. For small touch up stuff you don't need it. Just clean it up right, and the area around it which will see overspray, put a few light coats of rustoleum and you're good.
jsalbre
Jeremy
Idaho
‘21 Sarge Mojave, ‘21 VW Tiguan SEL-P RLine
Security Engineer, First Sergeant
First, most if not all the body is aluminum, so you don't need to worry about rust. Secondly, use some AEM on the nutsert before installation and no paint needed, it will seal up.
The body is not mostly aluminum, only the doors, tailgate, and hood (unless you have a Mojave, then you have a steel hood).
j.o.y.ride
Foster City
I thought the bed was too, if just the tailgate then ok.
Also, crossed brain wires last night. RTV (not AEM) should take care of any rust issues..
oscarach
oscarach
Paul
Houston, TX
Thanks for the info guys
