I plan to have them fully functional for being off-road at night. I may end up going with 12 lights to make sure I have everything illuminated underneath. Thanks for the tips and response!I have the LUX rock lights on my JK and they work really well. However, I picked up a set of 8 on ebay for about $40 about 5-6 years ago on a no reserve auction. Just couldn't pass up that deal.
A little off topic, but functional rock lights don't belong just in the fender wells above the tires. The whole idea of real rock lights is to provide full light coverage under & around the vehicle for night spotting. Putting the lights in the fender wells results in a big shadow under the vehicle and around the tires. If you are just going for the look, then forget all of the above and put them wherever you want.
I run 8 on my 2-door JK, so I was thinking a minimum of 10 on the JT:I plan to have them fully functional for being off-road at night. I may end up going with 12 lights to make sure I have everything illuminated underneath. Thanks for the tips and response!
So I know it’s only been a few months since you post about these lights but I’m about to pull the trigger on them. How is the RGB lights holding up? I planned on getting the Max White but now I see the RGB with White feature. Did you also get the Bluetooth controller? I think I’m going with the single zone. Any feedback or advice to offer?LUX Lighting systems hands down. I have the Max RGB system. I have 12 lights total. In the pictures I only have 4 installed. I have the other 8 sitting on my work bench waiting to be installed but currently in the process of trying to move so that got put on the back burner. They have full RGB capability with a pure white setting. These mount magnetically so if you are working on the trail and need to move one to redirect light then you can with no issue.
https://luxlightingsystems.com/products/max-rgb-color-changing-led-rock-lights
