Building a Mojavicon: Adding Lockers and Swaybar to a Mojave
Beowulf
Jeep Wrangler Rubicon Unlimited
I really like all the updates to the Mojave, but still want the OEM sway bar disconnect and front locker.
What are the chances, the wiring harness is the same? Also, wondering if the fox reservoir location would impede the installation of the OEM swaybar disconnect.
Items needed?
Most likely need
All in I'm guessing around $2500 or less to add everything to have a Mojavicon.
Let's hear your thoughts on doing this. Let's not do a debate on Rubicon vs Mojave, there are other threads for that. I just want to discuss the creating this combo.
mopar-77072413-locker-switch-harness-jeep-wrangler-unlimited-rubicon-jl-jlu-tabletop-main.jpg
Advertisement
Lake Martin, Alabama
You'll probably need a master install kit for shimming and setting backlash on the front diff with the new locker and gear set. Every ring & pinion spacing is different, no matter how precisely and consistently they're forged and milled. You could luck-up, and it could be a perfect drop-in, and when you paint the gears, everything is getting 100% contact... But the odds of that are VERY slim.
Beowulf
  • Thread starter
  • Thread Starter
  • #3
I had planned on regearing anyways when I go with 37s.
capercrew02
Steven
Corona,Ca
Jeep WJ, BMW i3, Red JTR.
Following closely, but additionally, the locker switch you are showing is for a jlu, not the gladiator that also has the Offroad plus button.
Bjeepz
B
Canada
2020 Overland
I would skip the factory disconnect setup and go with an anti rock setup for simplicity and cost. There are also the JKS flex connects that ppl seem to like.
Jimmy
CO
1994 Land Rover Discovery, 2009 Toyota Tacoma
This was the first thing I thought of when I read about the Mojave! Add the swaybar and front locker... and if the transfer case gearing isn't low enough for the wheeling I do, then throw in a Rubicon case too. I suspect it's easier to do this than to take a Rubicon and swap in the stronger frame, front steering knuckles, hydraulic bump stops, etc.
ACAD_Cowboy
Francis
NY
15 jkur
Sorbs
Brian & Sunny
Colorado Springs
2020 Gladiator LE, 2018 2dr JLR 6-SPD, 2015 Hellcat Challenger
I’m running 37’s at 6,000’ altitude. No issues and I get 20 miles per gallon. Save your money. As a matter of fact, buy a Rubicon and put remote reservoir shocks on it. There, saved you thousands, and you have a better Mojave.
jwilson2899
Front Royal, VA
2020 Gladiator Rubicon Launch Edition, 2004 Wrangler Unlimited
System Engineer
One thing I’m curious of is it looks like the front shock reservoirs are mounted where the sway bar disconnect motor would go. I’m wondering if that was part of the reason disconnect isn’t available on the Mojave.
Beowulf
  • Thread starter
  • Thread Starter
  • #11
I’m wondering the same thing, but it would not be hard to mount that reservoir somewhere else.
WhatExit?
48th State
@Sorbs is right on target. I've said this before - buy and start with the Rubicon and modify it. You'll likely replace the shocks anyway so you're on your way to the Mojave (it means "Must-have Gladiator" around here :LOL: )
Beowulf
  • Thread starter
  • Thread Starter
  • #13
I’ve thought about, but just want to try something different.
Sal
Carlos
Miami
I
agree with this. This is for sale btw
Len
Len
Jeep
I wish Jeep would combine the Mojave and the Rubi, that would be the ultimate machine. I also believe that the Mojave has a wider stance so you may have to take that into consideration as well. Good luck and let us know how it works out. I would love to see that build.
Advertisement
Advertisement
