Clunking and squeak noise after 2 inch lift
AlexMasal
Alex
Australia
Jeep Gladiator
Builder
Hi,
I've recently had a 2 inch lift installed (springs front and rear, fox 2.0 shocks and extended front sway bar links)
The clunk noise comes from the front whenever I go over large bumps OR when the truck articulates from left to right.
The squeak comes from the rear lower control arm.
What are my options here? Has anyone experienced/fixed this?
I've attached two videos; one of each issue.
Thanks!
CaptNkllm
Downtown
2021 Gladiator
Who installed the lift?
Check to make sure all parts are right side up and not upside down.
Was it sitting on the ground and bounced a little to help it settle in before it was tightened down?
Are the springs set in the cup (above the axle) correctly?
Found on mine we put the lower control arms on upside down and it was rubbing on the frame as it cycled... Flipped them over and now its good..
Take a few min on you tube and familiarize yourself with the lift you bought..
AlexMasal
Alex
Australia
Jeep Gladiator
Builder
Thanks for the reply. I'll jump under the truck and have a good look over the weekend.
Fingers crossed I work it out!
Rubiwoo
Michael
Self Employeed
i agree. double check everything. loose all the bolts while it sits at ride height and torque everything down again.
