Pk2abilene
I know the diesel will tow less than the gas engine by about 600 #. Just guessing that at the diesels max tow it will kick the crap out of the gasser at the same weight. Am I wrong?
I do believe the lower rating is due to the limited amount of air for cooling purposes. Specs wise there will be no comparison between the two motors performance wise in regards to towing. I am specifically referring to how hard the engine will work from stops, climbing up elevations, fuel economy while towing, and acceleration while passing. The diesel will have 260 Hp and 442 lb-ft of torque which blows away the gas 285 Hp and a miserable 260 lb-ft if torque. For comparison a Honda Odyssey minivan has more torque than the Gladiator. For those that have never towed with a non-turbo V6 and low torque prepare yourself for high RPMs to get into the necessary power band while towing anything over 4K pounds.I know the diesel will tow less than the gas engine by about 600 #. Just guessing that at the diesels max tow it will kick the crap out of the gasser at the same weight. Am I wrong?
Also methinks the 3.0 is heavier -I do believe the lower rating is due to the limited amount of air for cooling purposes.
I've got the EcoDiesel on my GC too. Love the higher towing capacity and better fuel economy on the GC. Tows like a dream. While the engine is great, I've had nothing but problems with the diesel exhaust system (multiple forced regens, stuck in limp home mode - 15 MPH, ongoing check engine lights, etc.). Can't wait to get the SW upgrade, $3k check from the FCA dieselgate settlement, then unload the GC for a gas JT.I have an Ecodiesel Grand Cherokee and other than some initial teething issues the engine has been a beast. It is really compatible with the 8 speed transmission.
As said above the torque of this engine is very impressive.
Yes it will cost more to buy and yes it will cost more to maintain but getting 700 miles on a tank of fuel is nice.
The only reason I’m not getting one for my JT is that I’m planning on spending some extended time in Baja and the availability of ULSD is not certain.
What he said....More torque = better towing power.
Period.
Look for tow tests.
My commute is half hour at freeway speeds, which is what is recommended to clear the DPF. We've replaced just about every sensor on our exhaust system (by the way, sensors are not covered under the exhaust system warranty).Yeah I know of some people who have had a bunch of trouble with the exhaust system. Many of them seem to have pretty short drives as part of their routine schedule and that is not good for any modern diesel.
I'm waiting on the Jeep settlement too and will use the ~$3K as part of my down payment on the JT. However, we will be keeping ours as my wife had me sell her Mercedes and now "claims" the GC as hers....!!!
Correct, the 3.0 weighs 502 lbs and the 3.6 is somewhere around 332 lbs. so 175 lbs difference. It should also be noted the same 3.0 is rated to tow up to 9,200 lbs in other applications. It’s not the tow weight ability for the lower rating. It’s the cooling.Also methinks the 3.0 is heavier -
Not to mention that thing is going to be an absolute beast in rock climbing and off road use!More torque = better towing power.
Period.
Look for tow tests.
I’ve had a DEF pump replaced and would be PO’d if it were paid out of pocket for it. $3,200 if I didn’t have an extended warranty. I’m also waiting on the settlement $ too.I've got the EcoDiesel on my GC too. Love the higher towing capacity and better fuel economy on the GC. Tows like a dream. While the engine is great, I've had nothing but problems with the diesel exhaust system (multiple forced regens, stuck in limp home mode - 15 MPH, ongoing check engine lights, etc.). Can't wait to get the SW upgrade, $3k check from the FCA dieselgate settlement, then unload the GC for a gas JT.
