fixbroke
I've had the (dis)pleasure of driving a friend's F150 recently, and it reminded me that I really don't want an automatic transmission. However, my CTS-V has spoiled me for torque and I'm not sure if the Pentastar in the JT is going to cut it.
How feasible do you think it would be to swap a manual transmission onto the diesel engine? Assuming that the gas and diesel 8-speed transmissions are similar if not identical, it seems that a 6-speed should bolt up. Pedals and a clutch master should also be bolt-in additions. The gear ratios may be poorly suited to the low-revving diesel, but that could be fixed with the addition of some 37" tires. The ECU and TCU would probably not be happy, however.
It's likely to be too much difficulty and expense to go that route, but I can't help but imagine how perfect that combination would be. Cheaper than a supercharger, and with much better fuel economy.
