DHP
I searched for this but didn’t find anything specific to the JT. Apologies if I missed it and if it has already been answered, please link me to the answer
I'm following this thread at JL Wrangler Forum. https://www.jlwranglerforums.com/forum/threads/3-6l-ess-aux-battery-bypass.17293/
Basically the method I would use would boil down to disconnecting the AUX battery negative cable and using a jumper to still be able to use the ESS system off the primary battery. You could then potentially have the AUX battery as an emergency starter battery assuming you remembered to keep it topped off.
a summary another poster made of the options:
Here is a summary of all of the options:
Stock, dual battery - everything works as normal, ESS can be disabled, but the button has to be pressed every time the vehicle is started to disable. The downside is that if either battery goes bad, it will take down both batteries while the vehicle is off and be difficult to jump since you have 2 batteries with parasitic drain.
Stock, dual battery, Smart Start Stop, TazerJL, etc - Same as above but you don't have to press the button every time you start the vehicle.
Disconnect negative Aux cable - ESS is disabled and cannot be enabled. Upon every start of the vehicle an error stating to service the ESS system will popup on dash and go away after a few seconds, and a yellow light will illuminate and stay on. A bad AUX will not affect the main battery. Reconnecting the AUX will require a code reader to reset the ESS error.
Unplug PCR (ESS Relay), Disconnect AUX - AUX battery is disconnected, however ESS functions normally and works solely off the main battery, or needs to have the button pressed every time the vehicle is started. No error message or light
Jumper across fuse block terminals, Disconnect AUX - same as above, AUX battery is disconnected, however ESS functions normally and works solely off the main battery, or needs to have the button pressed every time the vehicle is started. No error message or light
Unplug PCR OR Jumper fuse block terminals, Disconnect AUX, add Smart Start Stop, TazerJL, etc - Same as above but you don't have to press the button every time you start the vehicle. No error message or light
Has anyone done this on their JT and have you run into any issues? Anything I should make sure to avoid?
