DIY Bedrail System
Mikegcny
Michael
New York, NY and NOFO, NY
2024 Wrangler Willys 4xe
Software Architect
Like some others, I decided to build my own bedrail system out of unistrut. I think it came out pretty OEM looking.
I purchased all of the material from McMaster Carr for about $130.00
In addition to the material listed, you will need some M6 1mm x 25mm long screws and some rubber washers for the lifting eyes. I also put some polyethylene that I had laying around from making table saw jigs on the back of the runner.
Future Design Notes
  • I am going to remove the springs from the strut channel nuts because they make it difficult to re position the slider.
  • I ordered some custom stainless ratchet straps in red to match the truck.
  • I am working on a fishing rod holder that will use knobs to attach to the rails.
  • I am working on a bed divider system that will attach to the rails.
Gatorized
ME/NH
Future Design Notes
Thx!
Rubinator919
Raleigh, NC
Future Design Notes
Well done, sir! I like your solution with the "sit on top" strut channel washers even better than mine with the regular square washers!
Mikegcny
Mikegcny
Michael
Software Architect
Thanks. The only slight problem with the washer I used is that they barely clear the body colored tabs in the back by the knockout. Not a huge deal because they do slide past them, they just rub. You can always take them off the track and re-position as opposed to sliding them past.
2020 SCRAMBLER
Los Angeles
2020 Jeep Gladiator
Excellent @Mikegcny!!! You just validated why I didn’t spend $1K for the trail rail option!
So the M6s are what attach the unistrut to the bedsides? Nutserts I presume?
Mikegcny
Mikegcny
Michael
Software Architect
Yes. You will need 12 of the M6 screws. You can use 20 mm length. The bed sides and bulkhead are already tapped so no need to use nutserts.
I did run an M6 tap through before I put the screws in because I have a spray in bed liner, which plugs up the holes quite a bit.
I used outdoor masking tape to make a hole pattern rather than measuring. I then transferred the tape to the back of each rail and drilled out on my drill press. I did notice that the hole pattern on the bulkhead was not symetric.
jurfie
Vancouver, BC
That looks great! Did you paint the strut, or is it powder coated?
Gatorized
ME/NH
My bed rail kit from BuiltRight just showed up - planning on installing this weekend - however factory bed liner has been sprayed in by the factory - some of the bolt holes have some liner over/in them - any suggestions on fast and easy way to clean out the bolt holes from the factory spray in bed-liner ?
@kosmos - It would be nice to have all the bed rail systems in one post for comparison of measurements - could you measure the inside of the channel and slot to add to the list. I’ve linked below the McMaster DIY info along with the Mopar trail Rails.
  • I added some M6 1mm x 25mm long screws and some rubber washers for the lifting eyes. I also put some polyethylene from making table saw jigs on the back of the runner..
The t nut dims are all on the product page on Amazon.com.
Perfect timing - here are the Trail Rail dimensions as provided by @Zebago - now we need to determine which Stainless Steel T-Nuts fit best...
6.35mm= .25= 1/4
10mm= .394= 3/8
16mm= .629= 5/8
31mm= 1.22= 1 1/4
Link:
https://www.jeepgladiatorforum.com/...or-me-gladiator-rack.27705/page-4#post-458355
McMaster rails
Mikegcny
Mikegcny
Michael
Software Architect
Is there are Wiki on this site? I think it would be a good idea to create a wiki of things like this. So many times I have to dig through forums and read the entire thread to put together a clear picture of what to do.
ex: On a Sport model, how to trim the 'closure panels'; How to replace your speakers.
spazzyfry123
Tyler
2020 JTR (Sold) - Now Land Cruiser
ME
I LOVE when forums do this.
2004blackwrx
Wappinger Falls NY
2004 wrx, 2005 xterra, 2014 durango, formerly 1998 wrangler
The rails look great. I am thinking of doing the same thing. My main questions is how will this work with accessories designed for the MOPAR bed rails. I would hate to do all this to save some money and then be stuck with rails that can't be used with cool accessories.
jhale1800
James
Huntsville, AL
Gladiator Overland, 2000 Ford Crown Victoria, 2011 Hyundai Genesis Coupe, 2017 Mazda3
