Does a inch make a difference?
kennyp
kenny
Gloucester Virginia
2020 Sport Max Tow
Extrusion team Lead
OK OK no comment form the peanut section! just kidding. 38x13.5x17 or 39x12.5x17. I didnt post price or make. Just asking on size choice and why.
cafecito
Lucas
Orlando, FL
2021 Gladiator Mojave, Granite Crystal
Corporate Tool
The one inch width is going to make a bigger difference than the diameter. More likely to rub on fender flares, steering and suspension components, harder to turn, less traction per tread block, etc.
I'd stick with 12.5 unless you really have a reason you need to go wider.
Beat Army
Peter
2021 Gladiator Sport S
Yes. Yes. Yes. Yes! Yes! Yes! Yes! Yes!
bleda2002
2021 JTR Firecracker Red
What brand do you like better? Realistically no, the 1/2 inch isn't going to make much of a difference and you are better off picking based on brand, price and tire type (at vs at vs rt). With the current price of 39s being 700+(I paid under 500 a tire when I got mine) I will not be going 39s again honestly solely because the price is outrageous for the small gain.
Lynn_F
Lynn
Fannett, Tx
2020 Gladiator Sport S
If the 39 is a BFG then the 38's are likely bigger anyway. 39" BFG's measure ~37.5".
Sometimes the real difference between xx" tires and yy" tires is only about half an inch, meaning 1/4 difference from ground to hub center.
Gotta go by the REAL tire dimensions, not "advertised sizes".
A 32" tire and a 33" tire, for example, is often only .6" diameter, meaning your truck would sit a whopping .3" higher (three tenths of an inch)
This thread could have sexual overtones to it.
Depends on who makes the 38x13.5x17 or 39x12.5x17 tires. They could be the same height.
kennyp
kennyp
kenny
Gloucester Virginia
2020 Sport Max Tow
Extrusion team Lead
I left the make of the tires out I didnt want any one saying one is better than the other because thats what they use. I look at there website and both had same difference on there size tire.
38 inch tire was 37.8 and 39 inch tire was 38.8
Darkspeed
Central Florida
2023 JTDR
With no nittos in stock these are what I’m looking at Maxxis TL00015300 RAZR Mud Terrain 40x13.50R17LT
If your going Up
