Does the max tow have a different tow hitch setup than the non max tow?
Stonesolo
Rich
Sugarloaf
2020 gladiator sport S
Printer
Are the hitches the same or different?
TrailHiker
Denny
2020 Jeep Gladiator JT Sport S, Black 1946 CJ 2A
All OEM tow packages in the Gladiator have the same heavy duty tow package options, with a bigger generator, added cooling, and use the same hitch receiver assembly. The Max Tow package on a Sport adds longer axles front and back, the 4.10 rear/front, and heavy duty progressive springs and shocks, which allows for the increase in towing capacity.
cheers
David_in_TX
Grand Prairie
2020 Gobi Max Tow
The Max Tow hitches are rated at 765 lbs. tongue weight. It is 10% of the 7,650 lb. max trailer weight. This may be due to the overall payload/tow rating but it could also be a stouter hitch...
Kevin_D
Inland Northwest
All OEM tow packages in the Gladiator have the same heavy duty generstor, added cooling, and use the same hitch receiver assembly. The Max Tow package on a Sport adds longer axles front and back, the 4.10 rear end and heavy duty progressive springs and shocks, which allows for the increase in towing capacit.
cheers
...wider...
And both front & rear differentials are 4.10 instead of 3.73.
Might be a bit awkward if only the rear was 4.10...
kevman65
H
J
If your JT came factory with a towing package, it has a Class IV receiver hitch.
If your JT did NOT come factory with a towing package, it does NOT have a Class IV receiver hitch.
Trim level has nothing to do with the Class IV receiver hitch, option groups do.
I don't know how or why a Class II bumper hitch is included, but some have these factory.
Both the Class IV and Class II are attached to a rear cross member that ties the frame rails together and strengthens the rear end.
kooltoys
Tony
Central Florida
21 JTD, 90 300zx TT, 07 Nightrain, MB 3.0L Diesel
AV Design/Programming
High Altitude (North edition) has this stupid class II hitch standard..
