Emissions and engine swap
Puch
Not a Jeep
I am considering swapping out the 2020 3.6 for ??? Not sure yet. After looking at a couple sites and this forum, I didn’t really find any great info on how emissions compliant a swap would be.
I understand that different states may have different laws for emissions or no emissions.
I’m sure I could contact a shop and ask specifically for my state (CT).
That being said, I thought I would post this in hopes that anyone who has purchased a swap or has done research already could share their knowledge for each state. I m not looking for long stories of success and failures or speculations. That will just make it harder for people to find quick reference.
What I was hoping for was something like this:
CT has emissions and you can’t do it. Or CT has emissions and you need to do XYZ to be compliant.
Do they put a sensor in the tailpipe, where you live, or just connect to the OBD port? Usually here, you just need the vehicle computer to tell the emissions computer that everything is fine.
Which is a real hoot as it means nothing. There's ways to trick that setup. VW knows how.
Puch
Not a Jeep
I think 96 and newer only use OBD. Older use the sniffer.
Sandevino
North Texas
2023 Jeep Gladiator Rubicon
Check the laws in your area as they differ wildly from state to state. If you’re state requires the engine to be one available from the factory for that model year, you’re not swapping anything unless you register it somewhere that has no such restrictions.
Kevin_D
Inland Northwest
Washington state did away with emissions testing in 2020.
However, it's illegal to modify emissions equipment, which you would do to perform an engine swap.
That's where the "gotcha" is going to be in some cases. You'd be modifying the equipment for that specific vehicle.
Some states say that you can only go newer with an engine (can't use anything older than the model year of the vehicle), and others are sticky about modifying emissions equipment at all - like you said - an engine swap would do at least that.
California says the vehicle with the swap has to be certified - pass an inspection and be labeled.
CT seems to have composite vehicle laws - if it's not as assembled, it's got to be registered as a composite vehicle. Some say that the number of cylinders must match what it comes with.......
A lot of conflicting stuff on CT.
EdgeMan
Shawn
FWIW, I know there's a forum member in MA, andd as you know MA is super strict. He's got a 392 or Hellcat I think in his gladiator. I'm looking into this myself cause it would be cool, and cheaper than buying a new Raptor/Raptor R and or a TRX in a smaller format.
Mav4x4Chris
Louisiana
2022 JT Sport Max Tow
Fire Truck Builder
(a certain tuning software) does wonders for anything GM. You can turn off basically everything in a newer LS vehicle - evap system, rear 02's, etc. You could gut a car of all its emissions systems and set it all to NOT turn on the CEL and to always show ready - so short of a tailpipe sniffer, an inspection station would never notice.
Modern problems require modern solutions :CWL:
HP Tuners does wonders for anything GM. You can turn off basically everything in a newer LS vehicle - evap system, rear 02's, etc. You could gut a car of all its emissions systems and set it all to NOT turn on the CEL and to always show ready - so short of a tailpipe sniffer, an inspection station would never notice.
The EPA will likely do to them what they've already done to several other companies doing that exact thing. One ended up going out of business the fines were so stiff.
Right now they are concentrating in diesels more than anything, but insiders suggest they are dead serious - especially since CA, VA and the EU have cracked down bigly.
Best not to openly name names ?
Escape.idiocracy
Rich
PNW
Jt
Hitchhiker
Not Washington state- maybe the people’s republic of Pierce and King County??
Rest of the state has been deleted and emissions test free for the last 30 years I have been here ??
Kevin_D
Inland Northwest
The bigger counties had testing (Spokane included) and the rest didn’t.
Either way, testing was abolished statewide in 2020.
AHenry014
Alex
Haddam Neck CT
2020 JTR
Having done an engine swap on a 2002 TJ, I have gotten away with it in CT on an OBD2 vehicle. I did a 5.3 LS swap, mated to the OEM GM PCM, and wired in its own OBD2 port. As far as the emissions "computer" knew, it was testing a 2003 silverado. I wasn't able to get the check engine light in the cluster to interface, so I ran my own light on the knee panel. I went to an emissions place on the Berlin Trpk and explained the swap to them (engine comp stating all systems good and ready for emissions testing). Aside from them being a bit apprehensive about the independent check engine light, they got me squared away without issue. All they said they had to do was change the engine size in the state's system and I was good to go. It was no longer a 2002 wrangler with a 4L, it was now offically considered a 5.3L 2002 wrangler. Being a 2002, its now out of emissions testing requirements, so that Jeep's good to go.
All that said, the CT law is that the swap must meet all the emissions requirements of the specific vehicle's year. So, if you have a 2020 gladiator, your swap must have all the emissions equipment that the 3.6 had on it; all o2's, catalytic converter(s), evap system, etc.
The EPA is now going after the big gas tuners. Know of a couple people who have builds going on starting to shit themselves because they are scared that they may not get any turner to tune their car. Know of a couple of tuners not taking any new customers. Just doing EPA comp tunes.
Hmmn, well, my info about who they had already gone after, who they nailed to the wall, who they took down and forced out of business is a year old. No surprise to see you post that..........
