royceda59832
I have been noticing engine pinging/detonation/knock for the past month or two - it happens under *light* acceleration in higher gears (6/7/8) when rolling on to the throttle. Most noticeable at about 40mph in 7th gear, when I go from coasting to accelerating. It will occur with similar frequency when the truck is completely unladen as when towing.
If I manually shift to a high gear and try lugging the engine, it does not occur. It is only in the specific light acceleration profile scenario mentioned above - which, unfortunately, is a common scenario while driving. Gasoline is 87 octane and the problem is irrespective of fuel station (tried Marathon, Speedway, Costco, etc). Upgrading to mid-grade or premium fuel is not a solution - the gas V6 in the truck is rated to run on 87 octane.
To what extent will the dealer or Jeep Wave cover a rental car if the dealer needs to keep the truck for a few days? I know the Jeep Wave says it covers "Same-Day" rentals, but I don't want to be car-less for several days if that becomes necessary. I also don't want to take it in, have them tell me they "can't reproduce the issue," and drive off with it again with no fix - only to have to waste my own time bringing it in again at another time.
