MATANZAS STING RAY
- First Name
- Steve
- May 11, 2019
- 7
- 276
- 389
- St, Augustine
- 2020 Stingrey Gladiator from Travis
Picked up my Stingray Gladiator Saturday from Travis and did some fuel mileage and tire pressure testing (wander curing) on the long drive home....
First day I adjusted tire (33' M/T's) pressure every 100 miles to gauge any change in steering wander. Every tire type will respond differently that mine so take my information with a grain of salt.... The Jeep's steering felt nice and tight but has some minor wandering and requires minor fine muscle motions to correct while driving which does lead to fatigue in the shoulders on long distance runs. Wander can be attributed to several causes, over inflation, tire type/size, wind effects or some looseness in a steering box/system.
Right out of the box, I checked tire pressure cold.... 40 psi and set off on the first leg. Immediately I noticed some "floating" (minor body oscillation) between all four tires... What I attribute it to is the shocks self-adjusting as it settled down within the first 20 miles or so... no big deal....
Day 1. 100 miles in, I had a fair amount of wander and the tire pressure check was 46 psi hot which I re-adjusted down to 40 psi. 200 miles in, a bit better with wander and tire pressure was 42 psi Hot, which I re-adjusted down to 40 psi. 300 miles in, wander getting less but still present and tire pressure was 41 psi hot, and adjusted down to 40 psi, last stop for the day was at 410 miles, again wander was better and tire pressure check was 40 psi hot. I'm fine where the wander is now, it's not the steering as much as tire type and psi... I think daily around town driving will be no issue. If I hopped on the highway, I might adjust down a few more psi to 34 cold... Of course I have to do this testing all over again as I'm putting 35's on later this week, LOL!
I also tested fuel mileage... Day 1, I ran pretty much 78 mph on cruise with some regular city driving mixed in. Happy to say I averaged 17.8 mpg with the 4.10's, 's and 33"s....
Day 2. morning check of tire pressure showed 36 psi cold. Made an adjustment to 35 psi and ran that all the way home, some wander still there but day 2 was more about fuel economy. I ran 70 mph on cruise all the way with some city driving mixed in and averaged 22.5 mpg... I'll take that !
Pentastar impressions... Have to say I was impressed with the performance. No it's not a Hemi or V-8 but it responded very well, sounded decent and the power curve was steady all through ranges. If I hammered it, it responded with no hesitation....
