JAY
Staff member
Jeep Gladiator Forum
JT
Admin
Some JL owners have reported that a fuse pull (and reinsert) technique may help cure some steering issues such as dead spot, loose steering, pulling, etc.
Link to original post at JL Wrangler Forums: https://www.jlwranglerforums.com/fo...like-it-has-play-and-drifts.3691/post-1132084
Here are the steps to take:
Updated Fuse Technique
Some have reported this fixed a few different steering issues such as the dead spot, loose steering, pulling, etc.
1. With the JL off, remove F34 power steering fuse.
2. Start the JL, notice no power steering by turning the steering wheel and dash message error appears. Do not drive it.
3. Turn off engine. Open driver door and close it so it completely turns off all dash lights. Let it sit for at least 5 minutes so all electronics fully discharge.
4. Reinsert F34 fuse, start engine, immediately turn steering wheel full left, full right, turn to center, turn engine off. Restart and take for a test drive.
Give the technique a try and let us know if it worked for you.
Advertisement
2020 Jeep Gladiator Overland 2013 Nissan Leaf SV
It's worth a try. Is there a brain in the steering box that this procedure resets?
MudderTruker
Sydney, Australia
Toyota Hilux SR5 and Jeep Renegade ... name is on the list for a Gladiator!
Computer dude
LOL ... I think this is more psychosomatic! Modern car electronics just dont work like this!
But hay, if it worked for you ... (checking its not 1st April)
redrider
Joe
Columbia
F150, Cherokee Laredo(4.0) Norton Commando, 3 Guzzi bikes and a Benelli 1130 cr
Seriously though. Could it be a cavitation issue? Fluid viscosity? Ambient temperature? Fluid reservoir level? Air pockets? The engine mounted PS pumps changed rpm with the engine. Is the electric pump constant velocity/pressure?
cecaa850
South East TX.
So rebooting your computer never fixed an issue you were having? He's proposing a capacitive discharge which is basically a reboot of the electronic power steering. It certainly can't hurt. If it's ultimately a mechanical issue though, this will do nothing.
PyrPatriot
Kentucky, USA
JT Sport S Sing-Grey - 18k miles since 11/2019; Honda Element 170k miles since 2006
so whos gonna be the brave one to try it first?
JL forums saying this worked. They also referenced someone on here replacing their steering box to fix the issue
ZTMAN
PENNSYLVANIA
2019 F150, 2016 JKU WW
Make sure the chicken bone is in your left pocket and thee eye of newt is in the left shoe.
Benny
Wisconsin
1997 TJ, 2008 JK, 2020 Gladiator
My steering is sloppy compared to my wife's '20 JL. Coming from a 4" long arm lifted JK to a stock Rubicon I didn't really notice it at first. Lol.
I work with control systems, sensors, and logic circuits in the crane industry. I've dealt with having to calibrate directional control systems which is very similar to what's being described here. However, those systems don't have a mechanical link from input to controls like the steering shaft and gearbox on the Jeep.
I'll give this a try this weekend and report back.
