Carolina Overlander
- First Name
- Jeremy
- Dec 7, 2022
- 2
- 7
- 16
- Inman South Carolina
- 2022 Jeep Gladiator Sport S
I got the Y connector cause I am using a Bluetooth OBD2 connector. I pulled out the 2 plugs from underneath the dash, plugged them into the connector used my OBD 2 to adjust speedo and keep fog lights on when high beams are on. I unconnected the plugs from the Y connector and went to plug them back under the dash (think those are the CanBus?). Well the bigger plug (High CanBus?) Went right back in no problem. The smaller plug (low Canbus?) Does not go back into the plug very well and when I turned on the radio wasn't working at all. I pushed and pushed that plug as much as I can and nothing. Any idea what happened? And second thing if I plug those 2 plugs into the Y connector everything works. Is it okay to have those plugs left plugged into the Y Security connector all the time?
Thanks for any help you can give
