Hot/Cold HVAC Buttons... Shortcuts for Max hot/Max Cold?
Bonanza
Southern CA
Sport S Max Tow Punk'n
A year into my gladiator ownership, one of the things that just plain SUCKS about the change from the JK to the JL/T is the HVAC/radio controls. I never use a dial to tune the radio-- that should be a button. Changing the vents from dash-floot-mix should be a knob (win for JK). Changing the blower fan temp should be a knob (win for JK). It is sooo frustrating to tap the blue/red arrows twenty times to go from max heat to max cold and vice versa. I dislike opening the climate screen to do so as well to operate the sliders. Brain-scratching change by the designers, but it is what it is.
My question is whether there is a shortcut or trick to get the temp to go max hot or max cold with one or two tactile button presses. I've had this happen before where I've seen the temp jump 15-20 degrees when I'm spamming it, but I can't recreate this reliably. Is there a trick I'm missing?
Before it's suggested, I hate automatic temp controls, in every vehicle I've ever been in. The JT is no exception.
Mac
MA
2020 JT Hydro Blue Max Tow
Why did you buy a JT with automatic temp control? They make one with regular controls.
Bonanza
Southern CA
I had to google search extensively to see that... I didn't know that was a thing before today. Huh.
Mac
MA
May be able to switch it out, I know people switch it the other way from manual to automatic.
Bonanza
Southern CA
The radio controls are linked to the panel I have, so I don't think they can be swapped. :(
SuburbanGP88
Willy
San Diego
2021 Jeep Gladiator Sport S
There is a max cool option but not sure about max heat
Bonanza
Southern CA
Yes but only through the touch screen. Of all the buttons in the world these Jeeps need, its all windows up/down, max heat, max cold. Why is the rear window defroster an option but not these. (Doh)
These new systems are designed differently. There's no easy max hot or cold, since the setting is for the temperature of the cab, not the temperature of the air coming out of the vents. Even in manual mode, the system controls the air coming out of the vents to try and keep the cab at the temperature selected. This is supposed to be a 'luxury' style system. Cadillac and Lincoln have been installing them for decades.
