ORACLElights
Peak Sponsor (Level 2)
- Dec 29, 2019
- 246
- 1,331
- 2,026
- Metairie, LA
- Website
- www.oraclelights.com
- Jeep Gladiator
- Occupation
- Automotive LED Manufacturer
With 100s of different LED lighting applications on the market, it's hard to find ones that you know work for your vehicle AND look great.
Luckily, Oracle Lighting has been in the business for 20+ years, offering innovative products for all applications, specializing in automotive lighting. We offer various LED strip sizing in single color or ColorShift that can be cut and soldered for custom lengths. These can be used in a wide range of applications for every vehicle!
Check out our most popular types of LED strips for your vehicle!
photo by Fai May Photography
LED TRUCK BED LIGHTS 60” PAIR W/ SWITCH
Introducing the all-new ORACLE truck bed lights! Featuring dual IP67 waterproof strips, this new kit matches function and design by illuminating your entire truck bed with a pair of 60-inch LED strips. Add extra light to your vehicle to see in all the dark corners or to give extra visibility at nighttime.
Because the best trucks can go off-road too, you won’t have to worry about these LED bed lights getting damaged by the elements. With an IP67 IEC rating, our LED truck bed lights are protected from any contact with harmful dust and full immersion in up to a meter of water.
Package Includes:
- (2) 60” Truck Bed Light Strips
- (1) Plug & Play Wiring Harness
- (1) On-Off Switch
- (2) Set Zip Ties
Product Specifications:
- LED Type: 5050 SMD
- Input Voltage: 12V
- Lighting Color: White
- Net Weight: 420g/14.82oz
- LED Strip Length: 60"
- Housing: IP67 Waterproof
- Running Life: 30,000 hrs
- Materials: LED Chip+Silicone
- Warranty: 1 Year
photo by forum member ffward
FLEXIBLE 15" SMD STRIPS - PAIR
The retail set includes (2) 15" Strips of waterproof LED strip. Strip can also be cut down into smaller sizes. Easy install makes this the ideal strip for enhancing your automobile's look. Strip is waterproof, and comes with a 3M adhesive for indoor or outdoor applications. Current draw is only .35A, which makes this an easy accessory to tie into other 12V components. Includes a 1 year warranty.
Almost Limitless Applications Including:
-Footwells
-Engine Bay
-Trunk/Cargo Area
-Marine/Watersports Lighting
-Behind Engine Grills
-Underbody
-Custom Interiors
-Sound Systems
DOUBLE ROW LED TRUCK TAILGATE LIGHT BAR
The ORACLE 60" Double Row LED Truck Tailgate Light Bar is the perfect way to add an extra layer of safety and functionality to your Jeep!
By simply inserting directly into your 4-pin trailer light plug, you'll be able to utilize an extra smooth running light that turns into an attention-grabbing brake light and turn signals. The strip also comes with a 12v wire which can be tapped into your factory wiring to create an ultra-bright, pure white reverse light.
Help yourself avoid accidents and bad drivers with the ORACLE 60" Double Row LED Truck Tailgate Light Bar.
Kit includes the following:
- (1x) ORACLE 60" Double Row LED Truck Tailgate Light Bar
- (4x) Screws
- (2x) Brackets
- Installation Instructions
*Product is covered under a 1 Year Warranty.
Package Includes:
- (1) On-Off Switch
- (2) Set Zip Ties
- Warranty: 1 Year
-Footwells
-Engine Bay
-Trunk/Cargo Area
-Underbody
-Custom Interiors
-Sound Systems
- (4x) Screws
- (2x) Brackets
