DaveNH
- First Name
- Dave
- Nov 13, 2017
- 18
- 300
- 270
- New Hampshire
- Hyundai Sonata
Jonda? Or Heep?Anything "COULD HAPPEN" by 2030!!! Jeep could be owned by Honda.
“So to answer the question bluntly, I love V8s, but I love electrification even more, because it can give me more acceleration, more power, [and] more torque in a better package, without hurting the planet. So I think it’s a better solution longer term,” he concluded.
But he's leaving out some critically important points. What electrification cannot do is allow you to "refill" your truck in 5 minutes on any street corner in America, nor can it travel 500+ miles on a single "fill". And until it can do those things, which are a L O N G way off, it will never go mainstream in this country. If you take away a guy's diesel truck and tell him, "Here is an EV to replace it" he will revolt. People will not go for that in the U.S. Americans are lazy and want convenience and fun. There's nothing convenient or fun about owning an EV.
Furthermore he's leaving out the fact that while driving an EV reduces or eliminates emissions, the factory that builds them is producing more emissions than they used to when they made ICE cars. So in the end, there isn't ANY benefit to the planet. It's a wash. Lithium mining is horrible for the earth, and disposal of batteries is horrible for the earth, and waste from manufacturing facilities of EVs is also horrible for the earth.
They just need to work on the range.there are some other advantages to EVs that most people do’t yet realize
1) the chemistry is changing and improving. By 2030 it’s quite possible that there’s very little lithium used compared to today.
2) the batteries life expectancy is already dramatically improved and surely will continue to do so. I expect 200k mile warranties to start arriving on them in a few years and that them lasting 500k miles to not be surprising soon after
3) the drive motors in several evs are already thought to last 1M miles. Don’t expect much improvement there as that‘s outlasting the vehicle itself in lots of climate regions
4) cost of ownership is much less as there are no belts, nearly no hoses, brakes last 4x as long, no lubricants to change and the fuel itself is much less, no intake or filter to be concerned with swapping or water intrusion
5) the lower cog itself decreases stresses on suspension and frame
6) the batteries when in need of replacement can go on to live an entire second life as backup batteries on homes and businesses and after 10-15 years there will be recyclable to some degree.
envison a 20 year old buying his/her first Jeep and then never needing another vehicle again. most people don’t drive 1M miles in a lifetime. I personally can’t wait to see the first EV wrangler on 40s embrass a v8 sports car or climb a 50* slope
Heres a little peak at some of the advantages a Jeep might have
https://ranger.polaris.com/en-us/new-electric-ranger/
This may make me sound like an idiot - but let me have a couple of smaller top-up batteries in the trunk that are universal and can be swapped out on the fly. They can only be used to recharge the main battery, so they're always empty first and easy to replace. Just have a core charge for them and be done with it. You'll be incentivized to use a traditional plug to charge, but not tethered to it when you don't want to be.They just need to work on the range.
That's a really good point.... a full tank every morning leaving the house saves an immense amount of time for most people overall.
500 would be nice as that would give you a number of days of driving local without having to charge up if you didn't have the opportunity to. Give me a 500 mile range and then kick in to gas if beyond that then you would have sweet spot.that’s true and billions of dollars in R&D is directed at that.
that new lightning is going to be a good bellwether because while 300 miles of range with 1500lbs of cargo is good, more people will want 400 and everyone is on board at 500 especially when 300KW+ charge rates arrive. Keeping in mind also that while needing to refuel from E to F on the road might not ever be as fast as pumping 32 gallons of fuel, a fuel tank every morning leaving the house saves an immense amount of time for most people overall.
