ImBackBaby
- First Name
- Jesse
- Mar 28, 2022
- 2
- 44
- 21
- Cleveland Ohio
- 2021 jeep gladiator willys
- Occupation
- Software developer
Simply presses anywhere into the honeycomb grill that is found on most jeep gladiators and some of the jeep jls. These use the 3/4" bullet lights found commonly on semi trucks and trailers. You will receive the 3d printed inserts and led lights for each.
Shipping is included. PayPal only. Message me for details.
Available colors:
• Amber
• White
• Green
• Blue
• Red
• Purple
Features:
• D.O.T approved
• I.P. 67 waterproof
• Shockproof
• Dustproof
• 2 wire easy to install
What you'll need depending on how you install them:
For fuse box installation:
• Wire
• Fuse piggyback
• 2 pin wire harness (optional)
Notes:
• Test each light before install to check for positive and negative.
• I recommend putting a wire harness by the grill in the case you ever need to remove your grill. It will make disconnecting the lights easier.
• I piggybacked off the 20 amp cig lighter.
• If you want to mix and match colors message me prior to ordering and I will update the order.
• Be sure to test each light before install. Sometimes white wire is positive sometimes its negative.
• Smoked lenses accept for the white lights. They are clear.
• Can be used as turn signals when you delete fenders but you they are led and you'll need a resistor kit to go with it.
Available colors:
• Amber
• White
• Green
• Blue
• Red
• Purple
Features:
• D.O.T approved
• Shockproof
• Dustproof
• Wire
• Fuse piggyback
Notes:
