ORACLElights
Peak Sponsor (Level 2)
- Dec 29, 2019
- 246
- 1,336
- 2,035
- Metairie, LA
- Website
- www.oraclelights.com
- Jeep Gladiator
- Occupation
- Automotive LED Manufacturer
Give your Jeep's rear a lift with these OEM replacement bulbs for the JT!
REVERSE LIGHT BULBS for JT (PAIR)
ORACLE Turn Signal LED Bulbs are Direct OEM Replacement Bulbs that feature a Quick-Fire response, are brighter than stock halogen bulbs and include a 1 year warranty. The ORACLE line of SMD replacement bulbs features an unsurpassed level of brightness and quality. This bulb utilizes 5050 SMD technology which produces vibrant light with sharp hues while consuming only 1/10th of the power of the factory bulb. SMDs increase safety when used in tail lights because they illuminate faster than incandescent bulbs. 5211-001
TAIL LIGHT / REAR TURN SIGNAL BULB (SINGLE) FOR JT
The ORACLE line of SMD replacement bulbs features an unsurpassed level of brightness and quality. This bulb utilizes 5050 SMD technology which produces vibrant light with sharp hues while consuming only 1/10th of the power of the factory bulb. These 5050 SMD chips are rated at 100,000 hours for continuous use. (Lumen Count = 270-306lm) Turn signal SMD bulbs will require the use of a "Load Equalizer" in order to prevent "rapid-flash". If using this bulb in brake light, reverse light, running light, etc you will not need to add a Load Equalizer. SMDs increase safety when used in tail lights because they illuminate faster than incandescent bulbs.
