1. Note: If you registered an account with JLWranglerForums.com before August 20, 2017, then you are already registered here. You may login here with the same username/password.
    Dismiss Notice
Lift and tires
  1. Kangarhew
    Kangarhew Member
    First Name:
    Bryan
    Vehicle(s):
    2014 Jeep Cherokee
    Dec 8, 2018
    North Carolina
    Liked:
    like you guys I’m anxiously awaiting even just being able to order my JT, and spending many hours thinking about, what my plans are with it. I am going to get the sport s with max tow package. My question is, if I put a 3 inch lift, could I fit 35’s on it without affecting my tow capacity too much? Or would it be better to stick to a 2-2.5 with 33’s. I’m also assuming that with the 4.10 gears with the max tow package, I shouldn’t have to regear for the larger tires.
  2. Byebyetaco
    Byebyetaco Member
    First Name:
    Vehicle(s):
    Tacoma
    Dec 6, 2018
    Logan, Utah
    Liked:
    This isnt like JK. A 2” lift will be plenty. Wont affect your towing. Gearing should be great still and have plenty of power to boot.
    Kangarhew likes this.
  3. OP
    Kangarhew
    Kangarhew Member
    First Name:
    Bryan
    Vehicle(s):
    2014 Jeep Cherokee
    Dec 8, 2018
    North Carolina
    Liked:
    Awesome, so 2” mopar loft with 35s it is!!
  4. TexTJ209
    TexTJ209 Well-Known Member
    Vehicle(s):
    1981 Jeep CJ-7, 1973 Jeep J2000 Gladiator
    Oct 19, 2017
    229
    Liked:
    253
    Just make sure to pay attention to the load capacity of whatever tires you buy, and you should be fine.
  5. AdrenalineRush
    AdrenalineRush New Member
    Vehicle(s):
    2018 Chevrolet Colorado ZR2; 2019 Ford F350 CC SB
    Dec 5, 2018
    Southwest USA
    Liked:
    I would think you should be able to run 35s with stock suspension, just by changing to Rubicon fender flares. I plan on running a 2" mopar lift and 37s on the Rubicon version JT I will be getting.
    Capman99 and dangerousone like this.
  6. eternus
    eternus Well-Known Member
    First Name:
    Jody
    Vehicle(s):
    2014 JKU Anvil
    Mar 23, 2018
    Longmont, CO
    263
    Liked:
    248
    With the Max Tow package, you'll have wide enough axles that I'll bet you can fit 35"s on the stock setup... question will be backspacing on Sport S wheels, if they're as deep as the Rubicon wheels then I don't doubt they'll fit. You can aftermarket the Rubicon fenders later if you are worried about "full stuff" rubbing on your existing fenders.
    I think I'm going to push for 33"s right out of the gate, but might consider 35"s without a lift... 35" tires just get so pricey.
  7. Mac
    Mac Member
    Vehicle(s):
    2014 JKU
    Nov 30, 2017
    MA
    Liked:
    Depends what you are towing, even with 4.10s 35s will have a big impact on towing on the highway especially if you are in a hilly area.
  8. OP
    Kangarhew
    Kangarhew Member
    First Name:
    Bryan
    Vehicle(s):
    2014 Jeep Cherokee
    Dec 8, 2018
    North Carolina
    Liked:
    I honestly won’t be towing much at all. I just want the option for the 4.10 gears, and for if I need to tow anything I have the capability.
    5JeepsAz likes this.
  9. DesertDog
    DesertDog Active Member
    Vehicle(s):
    Dec 9, 2018
    Utah
    Liked:
    I’m more worried about the power output of the Pentastar. I haven’t had anything less than a V-8 in a lot of years. Towing 4600 pounds regularly in the mountains has me concerned. Buying a gladiator is a bit of an emotional purchase for me. I sure hope it’s not a mistake.
Loading...
Share This Page
