MOPAR Front Facing Trail Camera - Parts List for starters
Membrain
Dirk
DFW TX
2014 JKURX & 2020 JTR
Place holder for my post-delivery DIY install of the MOPAR Forward Facing Trail Camera Assembly to my 2020 JTR.
From what I have discerned so far, here is the -
Parts List:
QuantityProductStock NumberApprox. Price EA
2SCREW. Heat Shield Attach.68090949AA$1.10
2PUSH NUT. Export.06510197AA$0.88
1NOZZLE. WINDSHIELD WASHER.68370210AA$6.22
1BRACKET. CAMERA.68396526AB$7.70
1GRILLE. Texture. Honeycomb.6QN24RXFAC$24.96
1HOSE. Washer. Body.68370825AA$6.77
1HOSE. Washer. Body.68370828AA$22.89
1CAMERA.68436466AA$147.96
1WIRING. Camera Coax68406737AB$45.60
1WASHER. Windshield Pump68310928AA$6.43
I have ordered and received the parts listed above.
First response to the order was that the camera was on backorder until late in August.
Membrain
Membrain
Dirk
DFW TX
Parts List:
While the camera coax does fit the camera, it is not long enough to reach the VCP located behind the back seat as noted in thread: https://www.jeepgladiatorforum.com/forum/threads/factory-trail-camera-install.29321/
I'm still hoping we do not need that part of the camera coax which might be referenced in the CHASSIS HARNESS...
Membrain
Membrain
Dirk
DFW TX
Ok, the effort for this snowballed to a point where my effort became more dependent on the efforts noted in the thread by Jimmy07 and Bryanklay:
https://www.jeepgladiatorforum.com/...a-to-gladiator-diy-writeup.35026/#post-568743
but I will go ahead and post what I've compiled for parts and pricing so far:
1CAMERA. Front Trail / offroad68436466AA$147.96
1WIRING, Camera Coax68406737AB$45.60
1Washer, Windshield Pump68310928AA$6.43
1Adapter RG-174 COAX9977-6-8$151.84
1HOSE, Window Washer, Front Jumper68382604AB$7.49
1HOSE, Washer Body68456244AA$13.45
1WIRING, Jumper68382603AB$21.85
1GROMMET, Windshield Washer Pump68382598AA$0.94
1GROMMET, Washer Level Sensor05152031AA$7.38
1MODULE, Video Processor (CVPM)68329740AE$321.20
2Hex Bolt (CVPM)6104378AA$0.88
2Snap in Nut (CVPM)6506955AA$6.71
1Rear camera6NN98VGVAD$171.60
Miscellaneous:
1Molex connector (CVPM)34824-0124
4Molex pins (CVPM)5600230448
1TE Connectivity (CAN IHS) connector5-2138650-1
2TE Connectivity (CAN IHS) pins1355717-1
110amp fuse tap
11/4" ring terminal
150' roll 22AWG red/black wire
2tesa tape (roll)
1"W" style crimp tool
1coax1 - 1m FAKRA Z (M-F)
1coax2 - 10' FAKRA Z (M-F)
1coax3 - 10' FAKRA Z (F-F)
1coax4 - 20' FAKRA Z (F-F)
1AlfaOBD$49.00
Total$1,022.85
AirborneTexasRanger
Daniel
Spring, Texas
2022 Gladiator Rubicon, 2004 TJ Wrangler X
Welder/CWI
I cant seem to find this part: Adapter RG 174 COAX 9977-6-8
can you tell me where you found it and what is it for?
