ORACLElights
Peak Sponsor (Level 2)
- Dec 29, 2019
- 246
- 1,334
- 2,032
- Metairie, LA
- Website
- www.oraclelights.com
- Jeep Gladiator
- Occupation
- Automotive LED Manufacturer
NEW! High-Performance LED Fog Lights For JK/JL/JT!
One of the newest advancements in ORACLE Lighting's array of lighting products, these fog light replacements fit the Wrangler JK, Jeep Gladiator JT, and JL Sport & Sahara vehicle applications. This direct-fit fog light features plug-and-play wiring for easy installation. These amazing LED units push out approximately 3000 raw lumens to light up the night! (Part #5846) These make a for a perfect pairing with the new Oculus for the JL or JT!
These high performance fog lights are perfect for the off-road adventurer who wants to cover new ground on the trail! This rugged design can operate even in the worst possible conditions. Each light utilizes a rugged Polycarbonate lamp housing to withstand impact and a Solid-State luminaire design for vibration resistance. The epoxy-sealed electronics avoid moisture and corrosion.
Product Features
- Black Bezel Color
- Optional Premium ORACLE Halo Pre-installed
- Total 1,600 Lumens Light Output
- High Performance Phillips ZES™ 5W LEDs
- Horizontal and Vertical Adjustability
- Advanced Optics Design for Optimal Visibility
- Precision Beam "No Glare” Output
- Easy “Plug and Play” DIY Installation
Recent Product Improvements
- Improvements in brightness and reliability by adding a constant current LED driver to the main circuit board inside of the lamp to control the halos.
- Increased Reliability- By conditioning the power going into the LEDs this prevents degradation which can shorten the overall lifespan of the product.
- Wider Input Voltage Range- The new SMD Halos can operate on a very wide voltage range from 12V-24V so that voltage spike can not damage the LEDs.
- Brighter/ More Even Light- by moving the heat load of the resistors off the PCB we are able to increase the number of LEDs on the circuit board without thermal issues.
- LED chips upgraded from a Cree LED to a Phillips Luxeon ZES chip. They deliver a very high efficacy 130LM/W ratio while having lower thermal output.
PM us for a forum discount and shop by Jeep model on OracleLights.com!
