Oil Consumption
Lowcaljeepin
Lowcaljeepin
Josh
2020 Jeep gladiator rubicon
Fabricator
One of the best parts or things about forums is all the fun of playing 20 questions.
It gets really exciting, like a really good murder mystery, when pertinent clues come out on page 2 or even 3. Then it's a real adrenalin rush.
Some of these remind me of an Ellery Queen or Agatha Christie, or even Isaac Asimov murder mystery, clues are scattered in every chapter and it's often late in the book where things really come together.
We and the OP really have no idea how much oil was in there. 7 quarts? I strongly doubt they'd put 7 quarts of new oil in if it's a warranty thing. They'd lose money, and they can't claim 7 quarts on the "paperwork". They get paid for 5. If the dispenser is off that darned much - says 5 quarts but puts out 7, think of the money lost on every 55 gallon drum.
I've yet to see anyone brag about the accuracy of their 3.6 dipstick. I've not seen every single one and not every member posts their dipstick accuracy, but so far, what I've witnessed says they are more of a go/no-go gauge. Most read above that casting on the end when full.
Ideally, you let these sit a lot longer than 30 minutes if you want REAL accuracy, but 30 minutes will get you close enough to know if it's low enough to add or not.
Why longer?
Because 5 quarts is assumed with the oil filter dry, and the oil filter housing empty.
When you remove the cap and release the pressure on the filter, the remaining oil in the filter housing drains down to the sump (not fast, but it'll get there)
So the only real way to know exactly how your dipstick reads with the correct oil put in is to drain it all, change the filter - and for me, I check the oil level engine cold, in the morning before it's even started. Since I won't be driving mine today, I'll probably wait until this afternoon since I drove it yesterday afternoon.
Mine absolutely does read above that casting, onto the "wire", when the correct amount is put in.
No oil on the stick isn't necessarily low enough to cause a light to come on. Depending on your driving at the time, speed, curves/corners, braking and so on, there's likely still enough oil for the pump to create the volume needed for the oil pressure to be acceptable. Nothing on the stick doesn't mean empty - but is a red flag.
Assuming a perfectly accurate dipstick where those hashmarks indicate full/1 quart low, in a perfect world, full/5 quarts is the very top edge of the hash marks, 1 quart low is the bottom of the hash marks, that means that the dipstick has a range of around 1.5 to 2 quarts, tops. That means there's still 3 to 3.5 quarts in it. And if it was checked shortly after the drive, some of the oil is still up in the galleries, tops of the heads, oil filter housing and so on. So, no, not on the stick is very unlikely to trigger a low oil light.
As far as "over-filled", because these aren't a straight-up container where every inch rise in fluid level is exactly 1 quart, you can't know there was 7 quarts - that's a guess. The sump and crankcase itself is an odd shape for sure. If you measured how much you drained out, then you can get a close estimate, but you can't tell from the stick. Only by draining and measuring can you know what was in it - ideally pulling the filter to let the filter and filter housing drain, waiting a few minutes, then pulling the oil drain plug, and measuring.
You drained down to below full for sure - how low was it as far as quantity when you drained then used the dipstick, no way to know for sure because those dipsticks aren't calibrated.
Back to the "oil consumption" thing - a quart in 1,000 miles is a lot of oil. If it's a leak, it's going to smoke on exhaust, likely drip. A drop of oil spreads out to look like a hell of a lot more oil. (I've owned and dealt with leaking vehicles for decades). Take even a teaspoon of oil and pour it onto something - you can spread that out over a square foot or more. It's going to burn and drip and make a mess.
Burning that much oil - it will destroy the catalytic converters, it will contaminate and mess up O2 sensors, and you may well see blue out the exhaust (with the cats, it might not come out like pre-cat systems). But you'll know it - possibly even some black oily residue at the tail pipe after enough miles of that.
There's roughly 3 ways for oil to get into the chambers to be burned -
Really nasty faulty PCV - you can check that out easily enough.
Rings - compression test or leak-down test can indicate that issue.
Valve guides - extremely unlikely with these.
Oil consumption via the combustion chamber may lead to carbon fouled spark plugs, detonation, poor performance (because of the impact on O2 sensors, as well as fouled plugs and valves)
Oil consumption via leaks - it can't hide for very long! It will show itself.
If it's the oil cooler or filter housing, for example, it may get into the valley and accumulate for a while then come down the back of the engine and appear like a rear main seal.
Now, before we hit page 2 or 3 - any other details we really should know to at least TRY to help? 🤔😁
I was simply asking if anyone had the same problem
Doesn't take a lot of searching with Google or even the Gladiator or Wrangler forums to come up with the simple answer -
no
and if they did have excessive oil consumption, the causes vary so it really wouldn't matter.
It's sort of like "I have a misfire, anyone else have a misfire? What's the fix?"
Could be 100 things.
On oil consumption, these have never been known for that issue - they are really pretty tight engines. (at least as far as excessive oil burning in the chambers - and that's often PCV, not really anything else)
Leaks - again, can be a list of things - valve cover gaskets is an issue on some, rear main has been an issue for a few - but not common, oil filter housing/oil cooler and/or the seals (o-rings) have been an issue for some in the past, but with leaks, you'll eventually find them.
Pull the spark plugs that are easy to get to and look at them - color and pattern. Oil consumption of any magnitude should show up there.
Mine is just one out of millions of these engines out there, but I can go 7,000 miles and not be a quart low.
I've never had to add oil between oil changes on any 3.6 we've ever owned - which includes multiple Grand Cherokees and 2 Gladiators. None were even a quart low at oil change time - and my last oil change was 7,200 miles, still in the middle of the stick.
Maybe others can relate if they've had to add oil between oil changes (I suspect many here don't go over 5,000 miles between changes, although there are a number here who do)
Never been an issue with either of my Gladiators. The stick always shows full when I check it.
The only time I added oil, it probably didn't need any. It was after a drive from Las Vegas to Albuquerque where I pushed it hard the whole way. The back end was sitting high in the hotel parking lot and the stick showed about a third or a quarter down. I was in a hurry, so instead of doing it right, I just added a quart and headed out.
The correct amount of oil, 5 quarts, may well read above the casting on the wire and up onto the wire just a little bit. Mine, with exactly 5 quarts, reads onto the cable/wire part of the stick. It did with my 2020 as well as the 2022.
If you drained it down to 3/4 way up on the hash marks, you already had it down a half quart - even more!
A bit over, even 6 quarts, won't harm these engines. Not that I recommend it, but it's not an emergency with 6.
Mine will read about like this with the proper 5 quarts - at times it reads a bit higher than that, and has never had more than 5 quarts in it.
A quart in 500 miles will be smoking.
If you smell burning oil, have you looked for LEAKS - like a valve cover leak onto exhaust?
How about oil from the rear of the engine, back to the transmission?
You didn't say how many miles you drove when you didn't see oil on the stick.
Not sure why you let so much out of it.........
Referencing the picture above - I checked mine today - it's about 48 degrees, the truck has been sitting since 3:00pm yesterday (it's about 3:30 pm today) and the oil has over 3,000 miles on it - still up to roughly where the red line is in the picture above. It's not dropped down onto the other part of the "stick" yet.
Blade1668
Darrell
N. AL.
I've had a few times when mine used some oil, factors of it was I-state driving while towing trailers and a lot of hills. I could actually smell the burning of oil. I did end up adding over a qt of oil. That was last year or before. I've not noticed it any this year even when towing.
I was getting concerned with it then. There's a thread on here from it. With many good points from ShadowsPapa and a few others.
I've had a vehicle or two that you stop at gas stations and check the gas and fill up the oil in the past. :facepalm:
49Truck
Grand Rapids MI.
1949 Jeep Truck
Tool Maker
I have a 2021 Gladiator, I did the same thing you did and drained some oil out my first 2 free dealership oil changes. These are the absolute worst designed dip sticks I have ever seen. The flat part of the stick should go farther up the wire area so it can be read more clearly. My truck does not burn oil though. Sorry to hear about your issues. I just bought the factory extended warranty for 8
years total before my 3-year warranty ended. I suggest you doing the same, so you do not have to pay for a new engine replacement down the road.
Maximus Gladius
Calgary, AB, Canada
2021 JTR, 2023 JTR
About the oil consumption thing, I have two stories to tell ya’ll.
I had this issue explained to me by two service managers at two different dealerships. The first time I was made privy to a consumption issue, a customer came in to say his gladiator was consuming 5L in a 10k km oil change interval. It was told to me that Chrysler deemed this within acceptable parameters and nothing was done.
The second time I was made aware I was directly asked by the second service manager if I could guess how many litres of consumption is acceptable before Chrysler deems there to be a mechanical problem ? Well, I knew 5L was ok so that’s was my guess. The answer is 1.5L/1000 kms. That’s 15L in a 10k km oil change interval. ITS BS!
In my 21 JTR with 80k kms on my second engine, I “burn” 1/4 L and the PCV sends another 1/4L to the catch can in 10k kms.
JonMN
Jon
Minnesota
I have only had one car with an oil consumption problem. Kept getting worse and worse. Kind of shocked when they told me 1 qt in 600 miles was still in spec! After a lot of time and consumption tests it got worse and I ended up with a new engine.
The funny thing was that there was never any smoke and no smell. Just a warning light about every two gas tank fills.
That's odd that there was no indication............ the cats can't have been very healthy after all of that.
JonMN
Jon
Minnesota
I wondered that too. They ran all sorts of tests before replacing the engine. Pressure leak-down, formal consumption tests. On the final work order they said borescope indicated scored cylinders. So German engineering is not really infallible!
