BlueScapegoat
Silly question maybe but are the oil drain plugs on the ecodiesel one time use? Or is there a crush washer or some sort of gasket washer that's supposed to be used there? I'm about to drive 800 miles and changed the oil last night. Wiped down the oil pan. Came out this morning to a wet pan below the bolt and a small puddle.
I just snugged it up more but at this point it's a good bit tighter than I ever tighten drain bolts on anything else.
I'll grab another bolt somewhere along the way if I need to.
