Question on Bed Mounted A/C Power Outlet
70deuce
Phil
Franktown, CO
20Gladiator/01TJ/96ZJ/83CJ7/42 MB/43 GPW/70M35A2
Retired Navy Pilot
If the cab has the center console mounted A/C power outlet option does the bed have the wire harness run for the bed mounted outlet?
Lost1wing
West Georgia
Retired AMT
There is a small harness that plugs into the existing harness. There are a few threads on this with part numbers and videos. Dash bezel, switch, harness and the outlet are the big pieces. I gave up due to part availability at the time.
Dust
Joel
NJ
UPS Feeder Driver
No…… But your dealer does! Pricey but worth it if you’re doing the OME installation like I did.
ErylFlynn
Brett
Washington
2023 Punkn Mojave, 2008 JK Unlimited Det Yellow
Not sure it is worth it, seems NOTHING can run off it. 400 watt is nothing. 3.4A is about all you can get out of it, which sadly is nothing to write home about. Might be better to just run a DC line for what you are doing, the only other real option is to mount your own inverter that is not so anemic. This should be a bare minimum 1500 Watt setup to be of any use.
Lost1wing
West Georgia
Retired AMT
That is precisely what I did.
Blackjeepjk
North West Arkansas
2020 Gladiator Rubi, 2015 2dr Jk hard rock rubi
100% agree
