RanchoShocks
Peak Sponsor (Level 2)
TL/DR
Level your JT and run a 35" tire without any issues.
The blue JT is a SPORT S on 35" tires
Experience the versatile, purpose-built Rancho® 1.5-inch “Level It” Suspension Systems for the 2020 Jeep® Gladiator Rubicon. These NEW, 100-percent bolt-on systems from Rancho Performance Suspension and Shocks allow for the use of up to 35-inch tires for capable, all-around performance. The “Level It” System also features a NEW Rancho exclusive innovation to the Jeep Gladiator: Rancho RS9000™XL Shocks with brandnew Dynamic Rebound Spring (DRS) Technology. The new DRS Technology is a unique internal system that includes a precisely tuned metal spring and fortified interior construction to provide additional control, reduce body roll and prevent rod overextension inside the shock. These new systems include a pair of front corner-specific progressive rate coil springs, specifically tuned to provide superior on-road comfort and off-road performance. The corner-specific springs ensure your Jeep Gladiator Rubicon maintains a perfectly level stance and ride. To maintain travel integrity, the 1.5-in. Level It System includes front 2-inch bump stop extensions, and front extended length sway bar end links. These systems are precision engineered to be 100-percent compatible with the Jeep Factory Electronic Stability System. Designed with 35-inch tires and 17-inch wheels with 4.5-inch of backspacing. Kits also allow the reuse of OE wheels and tires. Backed by a Limited Lifetime Warranty. Finish the kit with an optional set of rear RS9000™XL Shocks.
- Includes front Rancho® RS9000™X shocks with Dynamic Rebound Spring (DRS) technology
- Front bump stop extensions; front extended sway bar end links
- Designed with 35-inch tires**
- Compatible with OE wheels and tires
- Installs easily – 100-percent bolt-on system and detailed, full-color installation guide included!
