Do these attach to body or frame....and it looks like you can use for a small step as well....Work great!
Did not realize those were electronic steps>..how do you like them?Do these attach to body or frame....and it looks like you can use for a small step as well....
They attach to both. They have slide on brackets that sandwich between your body bolts. That is the major load bearing connection. But they also bolt into the holes along the pinch seem. I am a pretty big guy, and they don't move around at all.Do these attach to body or frame....and it looks like you can use for a small step as well....
Good deal...thanksThey attach to both. They have slide on brackets that sandwich between your body bolts. That is the major load bearing connection. But they also bolt into the holes along the pinch seem. I am a pretty big guy, and they don't move around at all.
