Rough Country Gladiator 2.5in Front lift kit
Status
Not open for further replies.
Dyersburg, TN
2018 Jeep Wrangler Sport
Give your Gladiator aggressive, good looks while providing enough ground clearance to run up to 35in tires with Rough Country's 2.5in Suspension Lift Kit. This easy-to-install kit offers a total transformation, giving your Gladiator a more commanding presence while retaining a smooth factory-like ride.
Rough Country’s 2.5in Suspension Lift features a set of durable front coil spacers, sway bar links and bump stops. This kit is designed to simply enhance the factory components, allowing you to retain your brand new coils to preserve the factory ride just as Jeep engineered it! For an impressive ride quality both on and off-road, this kit also includes Rough Country’s nitrogen-charged N3 shocks. These 10-stage variable valving shocks feature a durable 18mm spring loaded piston rod, huge 54mm shock body, and reinforced seals for a long lifespan of smooth performance.
Rough Country’s Jeep Gladiator 2.5in kit features a 100% bolt-on installation process for an easy, no-fuss assembly and includes a Lifetime Replacement Warranty for the ultimate peace of mind.
Features
  • Easy bolt-on installation
  • Increased ground clearance
  • Clears up to 35" tires*
billyjk7
Tony
Lincoln Nebraska
2012 Wrangler JKU on 40s and Tons
Can this be had with shock extensions so I can retain the factory fox shocks? Any need for a front adjustable track bar or longer front control arms to get the factory caster settings needed ?
Rough Country Suspensions
Dyersburg, TN
Yes you sure can! The part number for that kit is 63400 and is $129.95. Adj track bar and arms are not needed as the alignment is still within the factory specs with this kit BUT if you want to run them we do have them available also.
bangolia
Bryan
Garner NC
2014 JKU
Jeep advertises that a 35 can fit with a stock Rubi... What makes this any better?
Big Red Gladiator
Robert
Huntsville Alabama
Toyota Tundra (gone... Just totaled it 4/22/19) Now a 2018 Toyota 4Runner Limited, RX350 (Wife's) and soon a Gladiator LE
Features
Looks Great. What tires are those.
I will lift my LE if it ever gets here. :crying:
Lpugmire
Lane
Boise Id
2016 Jeep Wrangler
So this is essentially a leveling kit? It takes 2 1/2‚ÄĚ in the front just to level it?
Lpugmire
Lane
Boise Id
2016 Jeep Wrangler
Yes that is correct, the Gladiator was much more nose down than the JL.
Would it be possible for you to post pictures of a JT Rubicon with stock tires and rims before the lift and again after the lift with the same stock tires and rims so we can see the change in stance, height and clearance?
2020Jeep
Alex
Northern VA
2020 Gladiator
You have a leveling kit for the rubicon? I already have 35's, but would like the front leveled with rear
Status
