Service Auto Start/Stop after Aux battery delete
CWREN2472
charles
north east USA
2021 Gladiator Willys
Hello,
I've got a '21 that was working fine until the battery ate itself yesterday. I replaced the battery with a 94r, pulled the Fuse #42, and disconnected the Aux battery ground like suggested. The truck starts fine now but the service Auto Start/Stop indicator light won't go away. To be clear, it's been on since the first time I jump started the truck but didn't think anything of it since clearly the battery(ies) were no good.
Suggestions I found, tried, and which didn't help: disconnect the ground from the main battery again and wait. Disconnect the IBS and wait.
I found a suggestion that the IBS itself might be bad but don't know how to confirm that without just replacing it.
I don't really care about the Auto Start/Stop working. I bought it when one year old and it's never worked in that time but never gave an error before today. But I'd like to get the alert to go away if possible.
Thanks in advance.
rharr
Tucson, AZ
I would look up how to test your z fuse to see if you blew a circuit there.
NY JT
Ed
Northern NY
2022 Gladiator Willys Sport
You can always buy a Taser.
Freetime
Bruce
Aiken, South Carolina
2020 Gladiator, 1986 Suzuki Samuri, Safari TREK Pathfinder
Did you connect the Aux battery positive cable to the new main battery?
Sweetums
Utah
I disconnected the negative from the aux battery. But yes, the positive is still connected
Connected to the old aux battery or did you connect it to the positive of the new main battery?
CWREN2472
charles
north east USA
The old aux battery positive is still connected to the new main battery positive. The old aux battery negative is disconnected and taped up.
