Zybane
I haven't seen much on this topic so I thought I'd start one. I will be using my JTRD for very remote travel/remote camping in all weather conditions (more rough trail/rock crawling and I avoid mud). I'd like the truck to be as reliable as possible, and curious on other peoples thoughts below and if they've ever had a critical show stopping failure outside of a blown CP4. I consider a show-stopper something that even with all the tools in the world, if you don't have the right parts, the Gladiator isn't able to start and drive back to civilization.
1. CP4 High Pressure Fuel Pump: this one is obvious. I've used Hot Shots diesel treatment since tank 1 on the dealership lot and will be super cautious about never letting the truck run out of fuel, and priming as best as possible during fuel filter changes. A spare fuel filter will be in the truck at all times.
2. DEF/DPF: I will always have at least half a tank before venturing out. Considering carrying spare heater element for the tank. Is there any other sensors on the system that would be good to have that would actually prevent the truck from starting and driving away? What does a frozen DEF tank do to the truck? I will be having a full skid plate system installed to protect critical components like the DEF system and fuel tank.
3. Battery: I will have a triple redundant setup. It will have the OEM AGM battery installed. Then I will have about 6.4 kWh of "camping" lithium permanently installed (with roof solar). Thirdly, I will have a portable battery powered "jump" starter. I am considering installing a diesel supplemental cabin/block heater to ease cold weather cranking/use. I have also considered carrying a spare alternator, possibly even starter motor (although it appears to be hidden deep, may not be possible to replace without removing stuff). Along with associated belt(s).
4. Turbo: If this were to seize/fail, could it be removed when being remote and the engine still drive to civilization?
5. ECU: I'll have a GDE tuned ECU installed, with a second "stock" ECU carried on-board. Along with the trans tuner. (The truck also has a Tazer mini installed).
6. Water pump / Power steering pump / Tensioner-Idler pulley: Has anyone had any issues with these items? Are these even access-able in the field? Obviously the water pump is critical for operation. Is the truck able to be steered without power steering? (I'll be on 37" tires). I understand the power steering pump is electric and not pully driven.
7. Glow plugs / Glow plug module issues etc: Has anyone had any issues with these items?
8. Oil cooler / EGR cooler / Camshaft/chain failures: Anyone have any of these experiences?
9. Anything else under the hood: Air filter, I'll have spare water/water filtration capability for coolant, spare brake fluid/rubber caliper hose, spare fuses and relays, possibly some spare rubber hoses of various sizes.
10. Transmission: Being a ZF sealed unit, not sure if there would be anything to do about a malfunction here. Has anyone had any transmission issues on their diesel? From what I understand, It's a pretty reliable unit.
11. Transfer case: Any spare parts thoughts for this? Shift linkage? Reliability concerns? It will be getting quite a bit of use on my truck.
12. Driveline fuse/parts: From my understanding, the "fuse" of the driveline is designed to be the axle half-shafts, is that correct? If one to were break, it could be removed and you could still have 3 wheel or two wheel drive locked up. With 37" tires, considering going chromoly but concerned about eliminating that fuse point and possible affecting the driveshafts, universal joints, yokes or differentials etc. Any failure scenarios with the driveline that would prevent the vehicle from moving no matter where the transfer case selector is?
13. Suspension: Ball joints / Tie Rods?
14. In-tank fuel pump: Reliability?
15. Anti-theft defeat: I would have second key fob hidden in vehicle with battery removed. In case something were to happen to my normal FOB.
16. I would have basically all garage tools needed for repair with me, including lithium powered electric tools. A full kit just short of bringing a welding machine with me. Various supplies for field repairs. Tapes, glues, rubber, clamps, stainless zip ties, bolts, hoses, wires, solder, propane torch, plastic weld putty, metal weld putty, prybar. I may bring along at least the minimum requirement for battery welding+goggles. Some small steel and aluminum stock.
17. Of course full off-road recovery kit, including but not limited to: Front mounted electric winch (Xeon Platinum 12S), portable 3-ton hand ratchet puller for rear vehicle winching/precarious situation safety and backup for front winch failure. Chainsaw, Maxtrax set, Snow chains, Shovel, Sledgehammer, Pickaxe, Survival axe, multiple winch extension lines/kinetic ropes, snatch blocks, soft+hard shackles, tree saver, 14K lb Pull Pal, Bottle Jack, X-Jack Exhaust Jack, backup air compressor, 5-gallon diesel Jerry can, Starlink or inReach, Combat First aid kit (CLS Bag), fire extinguishers, off-road tire repair kits (will have Hutchinson Rock Monster dual beadlock wheels) with spare in stock location, various other survival items, ratchets, winch rope splice tool, etc.
18. I will have repair/service manual on my laptop.
So some show stoppers: Catastrophic failure of CP4 (medium likelihood), starter motor (low? likelihood), transmission (low likelihood), transfer case (low likelihood).
Please let me know what I've missed!
