SS5 CrossLink Lightbar Kits | 18-21 Jeep JL Wrangler | Diode Dynamics
Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
www.diodedynamics.com
2015 F-150 / 2015 Mustang / 2016 Camaro
Jeep Gladiator SS5 CrossLink Lightbar Kits | 18-21 Jeep JL Wrangler | Diode Dynamics 8Ucjyrm
Diode Dynamics is excited to introduce the SS5 CrossLink Lightbars for the 2018-2021 Jeep JL Wrangler!
Featuring the highest output intensity of any 5-inch LED pod on the market, these auxiliary lamps have been designed for maximum functionality, with patented technology and custom-engineered TIR optics, all in a durable package.
The Windshield CrossLink Lightbar Kit for the 2018-2021 Jeep JL Wrangler from Diode Dynamics allows you to mount eight linked SS5 LED pods above the factory windshield. These application-specific brackets were CAD-designed to bolt into place using factory mounting points above the factory windshield. No cutting or drilling required!
The Grille CrossLink Lightbar Kit for the 2018-2021 Jeep JL Wrangler from Diode Dynamics allows you to mount four linked SS5 LED pods in front of the factory grille. These application-specific brackets were CAD-designed to bolt into place using factory mounting points on the factory bumper. No cutting or drilling required!
Selectable Backlight. The Stage Series 5" LED Pods included in the White kit feature a selectable backlight with eight different color options, perfect for an extra styling accent, or for more visibility when you’re not using the main beam. Selecting your backlight color is easy - simply alternate the power on and off. There’s no complicated programming with a controller! The SS5's backlight fully illuminates the TIR optic, providing unique accent lighting that you won't find on other LED pods.
Jeep Gladiator SS5 CrossLink Lightbar Kits | 18-21 Jeep JL Wrangler | Diode Dynamics mkZoWXv
NOTE: Due to the yellow lens, the Yellow kit is only available with an Amber backlight color.
Jeep Gladiator SS5 CrossLink Lightbar Kits | 18-21 Jeep JL Wrangler | Diode Dynamics cnzWeN4
CrossLink: Unlike other options on the market that use multiple pieces to link pods together, we have designed a single-piece CNC aluminum link. This provides extreme rigidity, but is fully adjustable, for both straight and curved configurations.
Jeep Gladiator SS5 CrossLink Lightbar Kits | 18-21 Jeep JL Wrangler | Diode Dynamics Wt43uhK
Functional Output. Stage Series beam pattern options were designed with advanced optical simulation modeling, to shape the output in highly-functional beam patterns with high efficiency.
This output shot features ONLY (2) SS5 Sport LED pods!
  • Combo pattern combines both the Driving and Flood optics, perfect for all-around use. It shines light downrange in a focused 30x20 Driving beam to punch with distance, and fills in the surrounding area to create a full 70x30 degree pattern. With a row of driving optics in the middle, and a flood optic on the top and bottom, this has been designed to provide extra light for every situation.
Jeep Gladiator SS5 CrossLink Lightbar Kits | 18-21 Jeep JL Wrangler | Diode Dynamics lbuX7S
White or Yellow. This kit is available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Sport or Pro. This kit is available at two different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses nine high-intensity LEDs for 40W of total power. The Pro model steps things up in a big way, with double the total power at 90W. Click the Specifications tab to see more information.
Interchangeable Lens. Need a different beam pattern or color? You can swap it yourself! We offer replacement lenses that allow you to change the color or optic of your Stage Series SS5 Pods.
Snap-on covers. For states that require them, we also offer snap-on covers for your SS5 Pod. These covers are available in a variety of colors and keep your SS5 Pod clean and protected from dirt, dust, or whatever else the road throws your way!
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like your factory lighting components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email [email protected].
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Just a heads up!
All SS5 LED pod orders through 12/31 will receive a FREE snap-on cover for every SS5 pod purchased!
SS5 snap-on covers will automatically be added to your cart during checkout. Limit 1 per SS5 pod.
Don't forget, you can also send us a direct message for a free US shipping code!
John C.
Diode Dynamics
BAT
Blaine
Katy, TX
Man that must put out some light. Just the two I have in my bumper the SS3 put out a ton of light
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
They're the most intense pod on the market currently that we're aware of.
The SS5 Sport with our "spot" TIR optic provides 400,000 candelas... that's almost a mile of visibility!
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Just a quick reminder!
This is your LAST CHANCE for a free snap-on cover with your SS5 purchase, on us! Don't miss out, preorder your SS5s today before 12/31 at 11:59pm CST!
Stage Series LED pods featured in the image above: SSC1, SSC2, SS3, and SS5.
Click HERE to shop SS5 LED pods!
John C.
Diode Dynamics
MattHamilton
Hamilton, ON
2021 Jeep Gladiator Overland
Support Analyst
Are you shipping to Canada, or do you have a dealer network up here? Any idea what the duty on the grille lights would be, approximately? And of course, I'm assuming the JL mounting points are the same as the JT; can you confirm they are the same "no drill mounting points"?
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
We do ship to Canada but don't offer free shipping at this time due to the service we use here in the US.
I would recommend checking out ProLightz in Canada to save on shipping costs. They are a Diode Dynamics authorized dealer!
https://www.prolightz.com/
Our kits for the JL and JT are different and not cross-compatible. We have vehicle-specific bolt-on kits for the JL and JT that don't require any drilling or modification to your vehicle.
https://www.diodedynamics.com/catalogsearch/result/?q=Jeep+SS5
Please, feel free to let us know if you have any other questions!
MattHamilton
Hamilton, ON
Support Analyst
Thanks for the quick reply! Happy New Year!
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Don't miss your chance to save 15% off your entire order of lighting upgrades!
Coupon Code: USA22
Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
Note: Items on pre-order are exempt from the sale.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping during checkout.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
