BryantJT
I've reached out to support but I had 2 instances in the last 2 days where the Jeep behaved unexpectedly.
1- Yesterday while scrolling through options with the Jeep in park and running, I hit left arrow and cruise down button (res minus) and the dash blinked rock crawl and the ABS and BRAKE lights flashed and my brakes locked and I could not get them to unlock. The manual states, release the buttons and the brakes will release, similar to line lock. The jeep would not move against the locked brakes. I changed gears, changed to park, powered down, opened the door, closed the door and waited for the dash to shut down. On restart the lights were still flashing and brakes still locked.
At this point I cleared the 2 DTC codes that were showing, full reboot, 2 sleep cycles of opening and closing door and repeating. Upon restarting again, the issue persisted. I went to the live menu and brake hold was OFF, I cycled it on, and back off and restarted the Jeep and it was fine. I drove around and it was fine. I left brake hold OFF which seems to mean the ANCHOR mode doesn't work either but so be it.
2- This morning while in line at the security checkpoint for work, holding light brake pressure creeping up to the gate, the ABS and BRAKE lights flashed, SERVICE BRAKE SYSTEM, SERVICE START STOP all flashed and the brakes locked again. I ended up using 4hi and driving through them so I could pull over to the shoulder. I followed everything above and nothing would get them to release, even clearing codes and unmarrying the Tazer. I remarried it, ensured brake hold was still off, full reboot, 2 sleep cycles and restarted the Jeep. I only used enough brake pressure to get it in drive as they were still flashing and holding pressure. At this point I crept through the line using the parking brake to stop every time. At the wellness checkpoint I put it in neutral and set the parking brake. When I opened the door, alarms went off and it activated auto park. I cycled from neutral, to park, to drive, again, with the lightest pedal pressure that would release the shift interlock. As soon as I was able to move up to 10mph, all lights cleared.
I have an e-mail and a text into support but I'm not sure if I should unmarry and reconnect the oem module to ensure I can get home now or what to do as I haven't heard back yet.
Anyone else have a similar issue? I'm on Beta 3 FW currently.
