Oak
Just spent a week off road and did the update before I left. I kept having intermittent issues in 4low. I was only driving the rear wheels at times. I also had to manually shift when in 4 low or the transmission wouldnt downshift in 4 low. Everything seemed to work in 4 hi though. I also lost the light that shows if your in 2, 4h or 4low on the dash. I was able to trick it at times and go into 4 high and then back to 4 low without turning the engine off and it would seem to drive all 4 wheels for a while...at least I got out of the obstacles.
I tried unmarrying and remarrying and still had the issues come back.
Any thoughts? I did the update with the mini plugged in...would it cause a problem if you don't remove it to do the update?
