Tazer stopped working need help
  • Thread starter Deleted member 30519
  • Start date
  • Watchers 2
I just pulled over on the side of the road before work. My gears were shifting funny and noticed live functions were off for stop start now I have check engine light on and I don't know what to do. It says the 513 gears are still updated in the settings. Should I try to unmarry it ?
Sorbs
Brian & Sunny
Colorado Springs
2021 Ram TRX, 2020 Gladiator LE
The Tazer can read your CEL. Post up with the code.
I think I accidentally cleared them. I did a restart and check engine is off but I don't wanna end up breaking down on the road. Is my best option at this point to try and unmarry it and re do the 5.13 gears in the settings?
I did a full reboot and seems to be back to working with the live functions. I'm literally dropping it off now for my rear diff fluid change. This is scary
texanjeeper
2020 Gladiator Sport-S Granite Crystal Metallic
I.T.
I keep almost convincing myself to get a Tazer, then I read posts like this and I tell myself no way. The things seem to be more trouble than they're worth.
FLUndertaker
Oklahoma
Not true. I’ve had mine for almost a year without a single hiccup. I would bet there are thousands of happy customers and a handful of dissatisfied ones. As with anything you only hear from the ones who aren’t happy.
Sorbs
Brian & Sunny
Colorado Springs
Most folks with issues don’t RTFM. I’ve been using for almost 3 yrs between my JL and JT plus added a Tazer to my TRX. Can’t live without them. As for the issues above, the Tazer has nothing to do with gears beyond letter the PCM know they’ve been changed. Without a CEL readout this thread kinda is useless.
I bought mine from rubitrex and it did not come with a manual. The only thing that was in the box was the tazer and the update cord. I watched the YouTube videos from quadratec and figured out the basics. I've had it on a while and it's been fine even throught my trip to NJ and back for my re-gear. The mechanic programmed the 5.13 gears in himself and that was last week. Does anyone have a PDF for the full manual?
Hostile4Jeeps
Chad
MN
JTRD
It's on their website...
redfish
Scot
Summerville, SC
JL, JT
Strategic Account Executive
Did the person that did your gears use the tazer to set the new gear size , or was the tazer installed or umarried when the gear change was set?
I installed and married it few weeks before the re-gear trip. He told me all he did was went into the settings to set it to 5.13s.
Sorbs
Brian & Sunny
Colorado Springs
I gotta ask…how sure are you anything was done correctly? There’s a process installing the Tazer that most YT videos leave out, such as, marry, full re-boot, configuring settings, reboot, then leaving the vehicle locked and key away from its proximity range for minutes at a time.
Go to their website and RTFM.
IamPro2A
Connecticut and New Hampshire
'95 YJ, '07 Ram, '16 JK, '21 Sport S Max Tow
That sounds like it's unlikely he also did the full reboot and at least 2 sleep cycles after changing the setting.
