Thinking of switching to 5w-30 oil on 22 Gladiator Mojave 3.6L, will it do better for motor?
Rhino35
Richard
Phoenix
22' Gladiator Mojave
I live in Arizona and in summer, temp goes up to about 115, but in winter, temp goes up to about 65 and low's to about 35. Do you think overall, changing the oil viscosity from 0W-20 to 5w-30 make it better for the engine, or worst. And why?
Wildtoad
Thomas
Blythewood
2021 Gladiator Sport Willys
Retired, former mainframe computer bit twiddler
I think a lot depends on how you drive, where you drive, how hard on the engine you are. I use mine as a daily drive here in central SC, high humidity and hot or moderately cold with an occasional really cold snap in the winter. So I have no reason to use other than the recommended oil as they are far smarter (about oil) than I.
if history repeats, this could be a long thread.
Dweisman429
Daniel
Jasper Indiana
23 JT Rubicon, 95 YJ tons and SBF
Maintenance Technician
You are going to get alot of opinons here...but this is mine....
I just did my 1st oil change and it is 5w30 full synthetic and not looking back.
With that said, I change oil at 5k. It is probably early but it's a very easy interval to remember and keep on top of.
In the 2014 JKU that this JT replaced, it called for 5w20. And I did run 5w20 for the first 75k or so...until it started getting more valvetrain tick. Switched over to 5w30 at that time and the tick went away. She got totalled out at about 155k and it was still running good with no noise.
I also changed the wife's Acadia that called for 0w20 to 5w30 after the 2nd oil change.
This super light oil is OK for making fuel mileage in a test lab, but I really feel that it is too light for normal driving.
And if you are going to tow or do any offroad stuff, I definitely would think very hard about going to a higher viscosity oil.
Remember...they really only care that your engine makes it out of the warranty period. After that it's more profit for repairs.
The 'official' answer is that it is bad for the engine to use anything other than what is listed in the owners manual. It also provides them the opportunity to deny warranty coverage for any engine issues.
I put almost 60k miles on my Overland in the desert running 0W20 Synthetic with no issues. The engine was always quiet with no startup noises. I have 6k miles on my High Altitude with no issues or engine noises, so far. Since the setup is working fine, I don't feel a need to experiment or second-guess the engineers.
whysoserious
Joe
Central Texas
2021 JT Mojave, 2006 Rubicon
Professional former employee
Here's some food for thought...
jac04
CT
2021 Mojave, 2014 JKRX SWB
The JK is a different animal. The Owners Manual actually specifies 5W-30 as an acceptable alternate to 5W-20 for the engine oil.
For the JT, there is only one engine oil specified in the Owners Manual.
willys 41
Larry Olund
Pleasanton Ca.
2020 Jeep Willys
Machinist / Auto Technician
I run 5w40 in both my 3.6
Jeep Gladiator Thinking of switching to 5w-30 oil on 22 Gladiator Mojave 3.6L, will it do better for motor? 5w40
Aaron67
Aaron
Tx
2020 Jeep gladiator,2018 Jeep grand Cherokee trailhawk
Driver
Same engine but different vehicle. My daughter had a charger with the 3.6 with 65000 miles on it. She had oil changed at a quick lube type chain and they used the 5w-30 instead of the 0w-20 because they didn't sell the correct weight. Her car started the having the lifter/valve rattle by the time she got home about 2 miles. Just my limited experience.
wally1955
Walt
Kill Devil Hills
2022 Willys edition Gladiator
I am one that is not an engineer, but I am a believer in using the recommended viscosity and one that meets Mopars specifications. The big thing is to buy a high end product. I personally use Royal Purple 0W20 full synthetic and WIX premium filters. Many years and miles of experience with this combo.
dajudge
New Mexico
2022 Gladiator Rubicon, 2001Cherokee XJ
Network/Server Admin
When I got my 2022 I couldn't believe how noisy the top end was. It sounded like an old diesel. Switched to 5-30 and it is MUCH better. Your mileage may very.
TheRealStreetcommander
East Coast
None of your business.
I've run M1 0w40 Euro or Rotella T6 5w40 Diesel oil in my 3.6 from new. This drives many forum members bats__t crazy when I mention this. There are some threads that have documented this approach over the years, including some UOA.
I have not noticed any MPG changes from oil weight and my JT gets on the higher side of the typically real-world MPGs reported on this forum. Recently I changed from MT's to HT's and picked up a solid 2MPG while losing a hellacious amount of tire noise.
