PJZ
- First Name
- Patrick
- Dec 16, 2021
- 13
- 333
- 478
- SoCal - The Valley
- 2022 JTRD AEV370
- Build Thread
- Link
Bought these for the JT before it arrived. Turns out the lift has a new UCA bracket on the front and these won't work for me. Needs to be stock suspension or lift without an add on bracket to lower the UCA. Part of the bracket needs to touch the frame which it cannot do with the lift's lowering bracket for the control arms. Never installed, brand new (installed pics are from RH4x4 site). My loss is your gain. Also fits JLs. Specs below.
$80
Prefer local pick up but can look at shipping on your dime.
Located in LA - out in the Valley
Rock Hard 4x4 is very proud to offer the Heaviest Duty 1/4" Thick Control Arm Skid Plates for the Jeep Wrangler JL and Gladiator JT.
100% bolt-on skid plates for your vulnerable front upper control arm mounts.
Total Weight: 5 lbs.
Our 1/4" thick skid plates are made from a solid sheet of steel then bent, formed, and hand welded into it's highly protective shape. Notched for zerk grease fittings found on common control arm joint upgrades.
Front Control Arm Skid Fitment
2020 - Current Jeep Gladiator JT front
Strength
Our skid plate system is the industry standard because of the confidence it instills in each and every customer. Each control arm skid is laser cut from 1/4" thick steel coated in our weather and debris resistant powder coat finish. Strength is proven on virtually all Jeep enthusiast forums with glowing reviews. Since 2007 our skid plate system has been the undisputed leader in undercarriage protection.
Three Reasons Why:
Installs in minutes
1/4" thick plate steel
Unmatched quality and fitment
$80
Strength
Three Reasons Why:
Installs in minutes
