California Front Frame Side Upper Control Arm Skid - stock or spacer lift only
PJZ
Patrick
SoCal - The Valley
2022 JTRD AEV370
Bought these for my JT before it arrived. Turns out the AEV lift has a new UCA bracket on the front and these won't work for me. Tried on my buddies JL a Teraflex lift and same issue. These likely will only work on a stock JT/JL or with a spacer lift. The skid needs to rest up against the frame to work properly. Can't do that with a drop bracket on the control arm.
$100. might look at shipping - guessing $15-$20 since they are heavy - buyer would need to pay the additional.
Located in LA / Valley. Headed up north to Monterey, Quincy, Tahoe and Mammoth July 10th - 19th if anyone happens to be in those areas.
https://www.rockhard4x4.com/product_p/rh-80516.htm
Rock Hard 4x4 is very proud to offer the Heaviest Duty 1/4" Thick Control Arm Skid Plates for the Jeep Wrangler JL and Gladiator JT.
100% bolt-on skid plates for your vulnerable front upper control arm mounts.
Total Weight: 5 lbs.
Our 1/4" thick skid plates are made from a solid sheet of steel then bent, formed, and hand welded into it's highly protective shape. Notched for zerk grease fittings found on common control arm joint upgrades.
Front Control Arm Skid Fitment
2020 - Current Jeep Gladiator JT front
Strength
Our skid plate system is the industry standard because of the confidence it instills in each and every customer. Each control arm skid is laser cut from 1/4" thick steel coated in our weather and debris resistant powder coat finish. Strength is proven on virtually all Jeep enthusiast forums with glowing reviews. Since 2007 our skid plate system has been the undisputed leader in undercarriage protection.
Three Reasons Why:
Installs in minutes
1/4" thick plate steel
Unmatched quality and fitment
