Fuse to tap to indicate the Engine is running.
danimal2000
Chicago
2021 Jeep Gladiator Willys
FYI cigarette lighter circuit also not powered until u put the truck in run. It is not powered with remote start. Need to step on brake and press the button for it to get power
Heated seat fuse is live with remote start. Not sure if this changes anyone's use, but thought I'd share the info
Kind of interesting, when I turn off, cigarette lighter circuit is still live until the radio and such shuts off (30 second delay or whatever it is with doors on). Heated seats are off immediately, no delay.
mklunder
Mark
Washington
2022 Jeep Gladiator Rubicon
Engineering Manager
I believe the cigarette lighter is on when the Jeep's engine turns off when it idles at a stop. I want to avoid charging my house battery when the alternator isnt producing power.
The remote s
Mark,
I just installed my BCDC 1225 and fused blue wire to cigarette lighter fuse!
works perfect charging a 100AH lithium
Did you disable the idle stop/start?
BunkieJeeper75
Conrad
2023 Gladiator Rubicon
construction
The remote s
Yes I have the idle stop/start disabled using a tazer JL mini.
